Go to Post they just build excellence and silently wait to deploy their creation on the unsuspecting masses - Koko Ed [more]
Unread 07-01-2012, 17:56
yclee31's Avatar
yclee31 yclee31 is offline
Programmer, Electrical, Design, etc
AKA: MINS
FRC #2429 (LCEC)
yclee31 is a jewel in the roughyclee31 is a jewel in the roughyclee31 is a jewel in the roughyclee31 is a jewel in the rough
Smile Tube scoring idea
As soon as I finished the kickoff video, I was thinking about using tube to carry a ball and sort of just dropping them over the hoop. Yes, I will only be able to use this for the 2 point hoops but I thought it would be the most insuring way of scoring safely rather than shooting.
Please replay any pros and cons about the idea and tell me what you think
Unread 07-01-2012, 18:40
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Tube scoring idea
How far out will that tube extend?
(since 2004)
Unread 07-01-2012, 19:01
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Any answer greater than 14 inches is a wrong answer, that's for sure.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 07-01-2012, 19:09
jzhu jzhu is offline
FRC #1391
jzhu is an unknown quantity at this point
Not necessarily, the rule says your robot can extend up to 14'' in any direction but max height can be 84''. Do the geometry, you can have a lot more than 14''
Unread 07-01-2012, 19:18
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
I think being more "automatic" in your shooting will be a great benefit this year, so you are on to something.
If we assume you are going back and forth to get balls, keep in mind you would need to lower from 84" to 60" (at least) when on the other side of the field.
Unread 07-01-2012, 19:22
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
The most you can extend out it any one direction (barring height, so basically lateral) is 14".
No amount of geometry will change the length of a straight line.
Unread 07-01-2012, 19:24
sah sah is offline
FRC #2374
sah is an unknown quantity at this point
I believe that the fender prevents directly dropping balls in the hoop because the edges of the fender are more than 14" from the edges of the hoops. And don't forget about the fact that your bumpers will add more space to traverse. Those factors combined put the hoops farther than the distance robots can reach. Although, you could add a small piston on the end of an arm or something like that and that would compensate for the fact that the arm alone can't reach the hoops.
Unread 07-01-2012, 19:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
A glancing at the field drawings and doing a little arithmetic, the front edge of the hoop is something like 12.5" behind the front edge of the fender. If you figure your robot's bumper eats up 3.5" of your 14" extension, then your tube will be 2" short of the front edge of the rim. Something to think about in your design.
Also, this thread title seemed incredibly outdated when I first saw it. Scoring tubes is sooo 2011.
Unread 07-01-2012, 21:02
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Just give it a little more juice and spit the balls the extra foot.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 23:37
treffk's Avatar
treffk treffk is offline
botgirl
AKA: Kelli
FRC #1802 (Stealth)
treffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud of
First of all:
[R02]
The Robot must satisfy the following size constraints:
horizontal dimensions must not exceed 28 by 38 in.,
the absolute height must not exceed 84 in.,
the height of the Robot at the start of the match must not exceed 60 in.,
any appendage may not extend more than 14 in. beyond the frame perimeter, and
no other part of the Robot may extend beyond the vertical projection of the Frame Perimeter (with the exception of minor protrusions permitted per 0).
Secondly:
A Fender is located directly below the Hoops at each end of the Court. The Fender is designed to protect the Hoops from damage by Robots. The Fender is 38-3/4 in. deep by 101 in. wide and measures 8-1/4 in. tall at the front, and 10-1/4 in. tall at the back against the Alliance Wall.
From my take on these 2 rules copied directly from the manual and the other factors that the hoops inner diameter is 18 inches and the hoop is 6 inches away from the backboard(at the narrowest part). 38.75-(6+18)=14.75-14=0.75. There would be no possible way to be directly above the hoop. This is just my take, please correct me if I'm wrong.
"If you always says yes, what are your yeses worth?"
Alumna of FRC Team 1802
Unread 07-01-2012, 23:40
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Are we talking only in Euclidean space, or can we generalize to non-linear space?
Attending: MN Duluth Regional
Unread 08-01-2012, 02:48
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Our robot design idea is use more then the first 4 dimensions. We are taking advantage of an alternative universe where our ball is allready in the hoop and switching that ball with the ball on our robot in this dimension. In one universe our robot does terrible, but great in this universe. The balls might be different(depending on how you interpret quantum physics), but I challenge the refs to definitively prove it one way or another.
Unread 08-01-2012, 03:12
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Don't forget that for this to work you would have to line yourself up with the hoops. You would be out of the "key" zone, so other robots could easily push you out of alignment.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 08-01-2012, 10:58
ThaineP
Posts: n/a
My team noticed that the 'safe zone' directly under the hoop is raised vertically a few inches, so it will be difficult to get directly under the hoops.
Unread 08-01-2012, 15:42
yclee31's Avatar
AKA: MINS
FRC #2429 (LCEC)
i was keeping rule [R02] in my mind too but was confused about the appendage part.. anyone wanna help me making that part clear?
so appendage must not exceed 14 inch from frame parameter. but does frame parameter refers to initial robot height parameter or 84 inch absolute parameter height? im guessing initial robot parameter but hoping for the absolute one
