Go to Post I would like to meet...Andy Baker: I've never met a pig farmer before... - MissInformation [more]
Unread 08-01-2012, 09:11
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
pic: Well Now What?
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: pic: Well Now What?
My guess is they will either open the hole or give you a tool like they did in 2009 and 2010 to grab dislodged balls.
Unread 08-01-2012, 09:43
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
My guess is the field was incorrectly built, and the GDC are already working on fixing that if their drawings for the fields were incorrect all together. Or you just helped the GDC figure out what they would have figured out in Week 1 and can fix it now to ensure that doesn't happen again. Having that problem is going to make Rule [G37] impossible for the referees and field crew.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 08-01-2012, 10:54
ThaineP
Posts: n/a
<G34> gives sticking your hand into the field a technical foul, so you'd want to find a ref or something about that, I have no idea.
Unread 08-01-2012, 11:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
So really what this becomes is a bonus for making a 'swish' into the high goal. Not only do you get 3 points, but your opponents don't get that ball. Awesome!
GitHub
Unread 08-01-2012, 11:17
Billfred's Avatar
Billfred Billfred is online now
I wouldn't bet on that--it doesn't look like that ball would have tripped the sensors to count it.
Unread 08-01-2012, 11:22
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I don't know about the sensors, but points are counted for the balls once they fully pass through the hoop by G38.
Originally Posted by G38
Alliances will be immediately awarded points for each Basketball that passes completely through a Hoop as follows:
[Table with Top/Middle/Bottom Scores]
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 08-01-2012, 11:23
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
But wouldn't you then get a penalty for not returning it? :/
Unread 08-01-2012, 11:34
Basel A's Avatar
AKA: @BaselThe2nd
Not at all! Take a look at G31. The ball never makes it to the corral, so it never has to be "removed immediately." There could potentially be 6 balls held by inbounders and an additional one stuck without penalty.
Personally, I'd call this a field fault and replay the match or simply fix it now to stop it from happening again.
Originally Posted by G31
Only Inbounders may contact Basketballs; each Inbounder may hold a maximum of two Basketballs. During Teleop, Inbounders must remove Basketballs from the Corral immediately upon arrival. All Basketballs in the Alliance Station must be held by Inbounders once removed from the Corral.
Violation: Foul
-Paul Copioli
Unread 08-01-2012, 12:47
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Can somebody just verify for me that in this picture that ball got stuck in the return chute just before it gets counted? What I see in the picture (or what I think I see) is the ball was never scored (it never went through the hoop) it just missed the hoop and got stuck underneath the goal just above where the balls return to the corral.
D5 Robotics: Member since 2007
Drive Team Coach, Design Mentor
Palmetto Regional attendee 2007-2011
2009 QF, 2010 SF, 2011 SF
Unread 08-01-2012, 13:19
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
I predict a return of the pokey sticks from 2006...
Unread 08-01-2012, 13:23
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
The ball didn't go in the hoop and return chute in this picture. The ball is sitting on top of the chute
2012-2016 Wave Robotics Team 2826
Unread 08-01-2012, 15:41
AKA: Brendan Browne
Correct, I had to shrink the image because of CD's size limit. The ball is sitting on top of the return chute just under where the hoop is mounted.
Again this was my second shot and I saw a few others land in the same area during the morning.
Brendan
1058 PVC Pirates 2016 - xxxx
Unread 08-01-2012, 15:49
ratdude747's Avatar
AKA: Larry Bolan
Brendan
a legal starvation strategy?
Unread 08-01-2012, 15:52
AKA: Brendan Browne
I'd rather put them in my lane than do that. 18 balls means if each robot has 3 there are none on the field or inbounders.
Any ball you get is a gift so starving in this game is realistically collecting your 3.
