Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
Unread 08-01-2012, 15:45
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
Surgical Tubing
It is possible to buy surgical tubing loops. If it is, where can we buy them. If not, could you recommend ways to make strong loops from the tubing we already have?
Thanks!
Unread 08-01-2012, 15:49
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Surgical Tubing
What are you looking to do with loops of surgical tubing?
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 08-01-2012, 16:03
laditek laditek is offline
laditek is an unknown quantity at this point
Re: Surgical Tubing
We have used polycord (metric) in the past and welded it together. To make the best loop. it must be stretched first and then melted together.
Unread 08-01-2012, 16:45
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Surgical Tubing
Surgical tubing can be tied, if you don't mind knots. Other options are pulling it over metal tubes or rods which are slightly larger than the inside diameter of the tubing, if it needs to pass over pulleys, you could try rubber cord instead of the rods,but I have no experience with that. Zip ties might help.
Unread 08-01-2012, 18:32
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Jibsy will become famous soon enoughJibsy will become famous soon enough
Re: Surgical Tubing
Last year we used zip ties. There was a little bit of slip with only one tie when under high pressure. To remove any slip you could attach the two ends with one zip tie, then fold the overlap back over the zip tie and add a second one there. I can't imagine there would be any slip potential left.
Unread 08-01-2012, 22:10
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Re: Surgical Tubing
The best method of connecting ends of surgical tubing that I've seen yet--especially if you want to use it as a loop is to cut about 1.5 in. of pneumatic tubing, then roll back .75 in. of the the surgical tubing onto itself (like folding down socks). Place a few drops of crazy glue on the pneumatic tubing (half of it). Unroll the surgical tubing onto the pneumatic tube. Duplicate the process with the other end of the tubing. The weld will NEVER come apart and is minimally larger than the original diameter of the surgical tubing. We have used that method for many years with no failures yet.
Now, as for the reason why you want to use it.... As mentioned above, use the poly cord it is perfect for this application.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 08-01-2012, 22:22
WillF WillF is offline
Team Captain
FRC #2945 (B.A.N.G (Bolts and Nuts Gang))
WillF is an unknown quantity at this point
Re: Surgical Tubing
Don't bother with complicated welds and gluings. It's just more effort than it's worth. Knots are just fine. If you are familiar with a water know (usually tied in webbing) it works fine due to the high friction of the tubing. If you don't know how to tie a water knot, look here. Another knot is the fisherman's knot, this works a little better and gives a better angle.
"Light a man a fire and he will be warm for a day. Light a man on fire and he will be warm for the rest of his life..." -Terry Pratchett
Unread 08-01-2012, 22:30
Kevin Ray's Avatar
Re: Surgical Tubing
You're making it sound as though the crazy glue is a bother. You can do the whole thing in a few minutes. The big advantage for Freewilly is that he can use it as a belt and there is no knot which might cause the belt to hop off the pulley.
Unread 12-01-2012, 18:09
NKP13 NKP13 is offline
FRC #0364
NKP13 is an unknown quantity at this point
Re: Surgical Tubing
Can someone please tell me the rules about surgical tubing, how much we can use, what type and of it we can use, thanks.
Unread 12-01-2012, 18:15
Happy Birthday! EricH EricH is offline
Re: Surgical Tubing
I can... but I'm highly reluctant to deprive you of the opportunity to do your own research.
I will tell you that using a Ctrl-F search of Section 4 of the Manual turned up no references to surgical tubing or elastic or springs; it did turn up a few references to tubing, but all of them were pneumatic tubing.
Unread 12-01-2012, 22:30
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Surgical Tubing
Yeah. We know you can read, and you can access the Internet. Look it up, you'll be the better person for it.
Unread 18-01-2012, 01:24
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Surgical Tubing
Am I the only one that misses the day when sarcastic reference to reading the manual also came with an answer to the original question?
I guess not. Come on, lets be the better person and not pick on the guy/girl. I'm not proposing that we answer every single question posted. I'm not even suggesting that you don't tell them to read the manual. I do suggest that if your going to do so in a condescending tone, you have the courtesy to answer the question to some degree.
Eric, this second part is more targeted towards Don and anyone else that may be tempted to such post.
Don, try not to let a bad day show through to your posts. Hope your next day is better.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 18-01-2012, 02:03
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Surgical Tubing
It didn't seem particularly mean to me.
Incidentally, a relevant issue with the manual is that it's unclear to new users what core concepts are likely to be found inside, and whether a particular thing is an embodiment of one of those concepts. We all know that the typical FRC manual contains references to springs, to pneumatic tubing and to fabricated parts—but it might be non-obvious at first glance whether surgical tubing necessarily belongs to one of those groups. There's no substitute for reading the manual, but a perfect answer would identify the logic behind mentally invoking particular parts of the rulebook (which never once mentions "surgical tubing", the likely search term). That way, the new guy can make the connection for next time.
Unread 18-01-2012, 02:13
Re: Surgical Tubing
A good weld is remarkably strong in polyurethane belting. A 0.375 in V-belt, welded with a hot plate (with a sacrificial metal sheet on top, and a jig to assure alignment) couldn't be separated by two people pulling very hard on it with pliers. (Granted, that's a sizable area under tensile stress, so a lot of force is logically required.)
That's a very good idea. Any information on which tubing materials work best for this? (Synthetic vs. natural rubber? Polyurethane vs. other pneumatic tubing?) I've had good success bonding various synthetic rubbers (e.g. neoprene) together with Loctite 409 cyanoacrylate. It's expensive, but works nicely for the purpose.
Unread 18-01-2012, 02:43
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Surgical Tubing
Thanks!
Am I the only one who noticed that the first sentence of the OP wasn't actually a question but in fact a statement?
Sorry, this is what a grammar-nazi does when he's bored...
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
