Go to Post Why do things the easy way when you can do it with a robot? - MissInformation [more]
Unread 08-01-2012, 15:56
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Bumper height zone?
I can't find in the manual what the bumper height zone is this year. Can anyone help me out?
Unread 08-01-2012, 16:00
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: Bumper height zone?
The Robot must have a Frame Perimeter that is comprised of fixed, non-articulated structural elements of the Robot. The Frame Perimeter of a Robot is defined by the outer-most set of exterior verticies on the Robot that are within the Bumper Zone, which is between 2 and 10 in. from the floor. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the Frame Perimeter.
I hope this helps
Building FIRST robots since 1995
BVT Robotics
Unread 08-01-2012, 16:03
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
It is hidden in the blue box under [R01]
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 08-01-2012, 16:30
jjenkins jjenkins is offline
FRC #2577
jjenkins is an unknown quantity at this point
Does anyone else see this as a particularly obnoxious selection? With a 6" barrier to cross, the maximum ground clearance of the bumper is 5". The bumper will hit the barrier before any other part of the robot can contact it.
Unread 08-01-2012, 16:52
GaryVoshol's Avatar
Cogito ergo arbitro
The barrier is only 4" tall - it's 6" wide. (Manual, 2.2.5)
(since 2004)
Unread 08-01-2012, 17:06
FRC #2577
Wow. TY. Maybe I should read the rule myself rather than listening to what someone else reads to me. Ugh.
