Go to Post If I understand what you're saying, you don't understand very far. - Alan Anderson [more]
  #46   Spotlight this post!
Unread 08-01-2012, 15:24
Dmiller28 Dmiller28 is offline
FRC #1241
Dmiller28 is an unknown quantity at this point
Re: Let's Talk About The Bridge:
Iv got a question... are we able to grab onto the bridge and hold onto the side of the bridge opposed to driving onto the bridge itself?
  #47   Spotlight this post!
Unread 08-01-2012, 15:46
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by davidthefat View Post
So at 1.5 feet out from the center, around 36 lb is required to tip it. How much does a battery weigh?
13-13.5 pounds
[G10]
Robots may not grab, grasp, grapple, or attach to any Arena structure. (Robots may push or react against any elements of the Arena that is not protected by another rule.)
Violation: Foul
  #48   Spotlight this post!
Unread 08-01-2012, 16:09
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Originally Posted by PAR_WIG1350 View Post
[G10]
Violation: Foul
This means you can still push down on the bridge though.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
  #49   Spotlight this post!
Unread 08-01-2012, 17:35
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
Originally Posted by Marc S. View Post
If you made a wide base robot you could have a larger intake and more easily fit 3 bots on a ramp.
Of course you make your robot more prone to tipping over if you want to go over the 4" bump.
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
  #50   Spotlight this post!
Unread 08-01-2012, 18:38
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
So in other words, go big or go home.
Taking from the new will.I.am song, you mean "You can go hard, or you can go home."
Anyway, here is a bit of thought that I'm sure many have thought about already: (please excuse the bad Sketchup drawing. I'm not finished with the final field.)
http://i48.photobucket.com/albums/f2...ingTheGame.png
Step 1: Carry Bot is on one side, with the other two on the other side.
Step 2: Carry Bot puts the Bridge on the top of their robot, allowing a robot to drive onto them.
Step 3: Carry Bot or the Third Bot moves the bridge down for the Two bots to get up.
Step 4: Two bots move to allow the Third Bot to get up.
Step 5: +40 Points.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #51   Spotlight this post!
Unread 08-01-2012, 19:06
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Step 5: +40 Points.
Heh, this came up yesterday.
You'd need something like this, and it would be pretty hard. Look at other '07 bots
http://www.youtube.com/watch?v=zgHanZXFweg
https://kusha.me
  #52   Spotlight this post!
Unread 11-01-2012, 00:23
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Has anyone built the "cheap" version of the bridge? Ours is pretty much built to spec but doesn't have dynamic properties coming close to the competition bridge in the FIRST video on their site.
Using 2 batteries, our bridge tips at about 15 inches out, rather than the 28" claimed. I did some math (explained below) and came up with a weight for our bridge around 70 pounds, whereas the competition bridge should be more like 170 pounds. Anyone else notice this, and what are your recommendations? I've thought about just adding 100 lbs of weights to the underside of the bridge, but didn't know if other people had more elegant solutions.
Math:
The hinges are 7" apart, meaning the pivots are 3.5" on each side of center.
Since the batteries weigh approximately 14 pounds each, and the center of gravity is approximately 3 inches inboard of that, we can calculate the balanced gravitational moment of the bridge and battery. For our home-built bridge, the battery side moment is (15"-3"-3.5") X 28 lbs. The balance bridge moment must be 3.5" X W[bridge]. Solving for W we get ~70 lbs.
Now, take the competition bridge in the FIRST video -- replace our 15" with 28" and you get 170 for W[bridge]. No wonder they said the field was particularly heavy this year!
  #53   Spotlight this post!
Unread 11-01-2012, 01:05
ThaneS ThaneS is offline
FRC #0167 (Children of the Corn)
ThaneS is an unknown quantity at this point
I've just finished our bridge and I note the same thing. Ours tips with the batteries at around 13". However, we haven't put a sheet of polycarbonate over the top yet. I think this should make the bridge less prone to tipping, as there is more weight keeping it in the center position (if my brain is thinking about physics correctly). Getting a 4x8 sheet of .25" polycarb isn't the easiest thing for us, but another sheet of .5" plywood weighs about the same (50 lbs), so that's probably what we're going to try first. The only other discrepancy between our bridge and the plans is that the plans seem to dimension the nominal thickness of the plywood, and not the actual, easily available, thickness that we used (15/32" instead of 1/2").
On a completely different note, I haven't seen much discussion of robots falling off the bridge. There's no lip on the sides, and if a wide robot tries to go over it, there's only 5" of clearance on either side. I expect to see a lot of tipped robots.
  #54   Spotlight this post!
Unread 11-01-2012, 01:07
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
There actually is a metal bracket on the edge to prevent robots from driving off; it's about 1 inch high if I remember right.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #55   Spotlight this post!
speedbuggy76 speedbuggy76 is offline
Manellis
AKA: Matt Ellis
FRC #0118 (The Robonauts)
speedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the rough
We ran into the same problem with our inexpensive version of the bridge today as well. Let us know what you decide to do to fix it, we need to work on ours too. We figure if our programmer can get it to work on this more finicky bridge, it should be good to go for the competition one
Mentor for Team 118 - The Robonauts
Former mentor of 2415 - The WiredCats
Former member of 1002 - The CircuitRunners
  #56   Spotlight this post!
Unread 11-01-2012, 01:15
Ah yes, I see you're right. I should have read the drawings more carefully. In that case I expect somewhat fewer tipped robots.
  #57   Spotlight this post!
Unread 11-01-2012, 01:27
MechEng83's Avatar
AKA: Mr. Cool
Another mentor on my team made that same point... on the other hand, the competition bridge will take significantly more force to push down than the economy model. These two features need to be balanced (no pun intended)
  #58   Spotlight this post!
Unread 11-01-2012, 01:36
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Step 5: +40 Points.
We had the same idea.... seems like an interesting way to go. Need to get rule clarifictions about robot piggy backing.... I wonder about possible bumper zone violations for the upper robot.
If all robots can be designed to climb a 30 deg ramp... then they could just drive over the robot using 14in ramp extensions and then you don't require the use of a bridge to mount. This would have to be a very low profile specilized robot.
  #59   Spotlight this post!
Unread 11-01-2012, 01:42
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
See the rule updates, all robots must be touching the ramp to be supported by the ramp. So now you just have to build a robot that can lift itself high enough to allow a robot to fit underneath. Maybe some team collaboration is needed.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
  #60   Spotlight this post!
Unread 11-01-2012, 01:50
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Djur View Post
Omniwheels wouldn't be too useful because they can slide very easily and don't have good traction; Mecanums are a bit more helpful because they don't slide as easily and have better traction; holonomic drive would be best because it doesn't sacrifice traction for mobility, but it's difficult to create. Just my 2 cents.
Holonomic drives sacrifice traction in the same direction mecanum drives do. Holonomic drives have just as little traction as a rubber wheel, in theory. In practice omni wheels don't have very much traction in any direction unless you double or triple them up. Combine that with a low friction well greased gearbox and you will realize the wheel wastes power scrubbing motion in the wrong directions with any holonomic system. I would not recommend one.
