Go to Post With any dollar amount to invest I would be more interested in the number of individuals (students is too narrow) impacted than the number of teams created--after all, this is about people. - kramarczyk [more]
Unread 08-01-2012, 16:21
rebug rebug is offline
FRC #1884
rebug is an unknown quantity at this point
Anyone know how to offload code to driver station? [xPost]
http://www.reddit.com/r/chiefdelphi/...river_station/
Unread 10-01-2012, 03:10
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: Anyone know how to offload code to driver station? [xPost]
Yes, our team did it last year. It is possible to transmit data over TCP/UDP to the robot and back through some open, but normally unused, ports allowed for the competition (they are found in the manual -- others might be open in practice, but only a few are guaranteed). I don't know the numbers specifically, but there is one port open for TCP for the camera, and one without an assigned purpose. Seeing as our team wrote its own dashboard, we had those and the one reserved for the dash.
So it basically turns into writing your processing program on the driver station, and then talking to the robot via TCP. I have some Java code, but the only important part is the usage of the networking library.
Unread 10-01-2012, 09:12
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Might I suggest using the new NetworkTable classes found in the robot to do your communication?
I've attached the .jar (well, a .zip containing the .jar) that you need to use a NetworkTable on any computer.
The cool thing about NetworkTable is that there is only one line of setup (NetworkTable.setTeam(...)) and then you just specify a table (like NetworkTable.getTable("random name I came up with")) and that table will exist on both the robot and the computer, and any change you make to it will reflect across both.
Even more crazy, if you use NetworkTable.getTable("SmartDashboard") and you install the SmartDashboard on your classmate, then you will be able to see what values are there on the SmartDashboard.
