Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Unread 08-01-2012, 18:03
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
2012 driver station update will not install
I am trying to install the driver station update on our teams laptop, but whenever I run the setup it gives me an error
Developer Error. The following Errors were found in your ini file:
1. Missing Section [Volume Id]
Correct the ini file and try again
I have been searching for awhile and have not found any mention of a similar problem.
does anyone know what might be causing this? or how to fix it?
Unread 08-01-2012, 18:09
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: 2012 driver station update will not install
I haven't done any updates, but I'd suggest checking that your laptop has the latest FRC image installed, and that you have a Driver and Developer login.
Unread 08-01-2012, 18:21
aeniug2's Avatar
AKA: Joseph
I am currently trying to set up 2 laptops for my team... One of them is team owned, and has the latest image and the other is being setup mainly as a development laptop (but we decided to try and install the driver stuff for the heck of it).
(the developer one does not have the image, it is being setup as a sort of test... side project... thingy)
Both laptops have handled all the updates perfectly up until now.
They both get exactly the same error.
Unread 08-01-2012, 22:35
aeniug2's Avatar
AKA: Joseph
Problem solved. Apparently the file was corrupt because the computer was tampered with while it was downloading everything. All our teams laptops are now updated and ready to go.
