Go to Post Before joining FIRST, I sure wanted to be SUPERMAN or SPIDER MAN!....but after joining FIRST, I realized that there are other ways I can help people and the world. - RoboMadi [more]
Unread 08-01-2012, 18:10
rhf323's Avatar
rhf323 rhf323 is offline
El Capiton
AKA: Ryan Fuller
FRC #1458 (Red Tie Robotics)
rhf323 is an unknown quantity at this point
Ultra Sonic range finder Possible Problems
Hey Guys
I may have found a problem when multiply teams use the ultra sonic range range finder. In my past experiences when using a few of these sensors at the same time they interfere each other causing their data to be Highly inaccuracy. The reason for this is that they way sensors work is that the send out a sound inaudible to the human ear and time how long it takes for it to return to the source. Then through some simple math the distance is found. But when 2 sensors are used sensor #1 can pick up the initial sound from sensor #2 causing sensor #1 to out put incorrect data.
So any thoughts on sloving this problem if it does exist?
Measure twice cut once
I dont care what you do just get it right the first time
