Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 08-01-2012, 18:55
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Re: Labview Update Does nothing - Help
This does not help with your particular problem.
But I installed LV FRC 2012 and the LV Update on a Windows7 64 bit OS and did not have any problems.
The update ran properly and I have the FRC framework and the FRC imaging utility.
Unread 08-01-2012, 22:40
Did you extract the zip file, or are you trying to install from inside the zip file?
I'm also running on Windows 7 64 bit without trouble.
Unread 08-01-2012, 22:54
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
I was experiencing this as well, moving from last years Labview to this years... my fix, Control Panel>Add/Remove Prog's>National Insturments and I literally uninstalled ALL traces of National Insturments. Then installed off the fancy little card like normal, and BOOM! Worked, from there I did the Driver Station, Utilities, and Labview update .zips from NI... and I'm running 100% (First year this hasn't been a pain!!! ) sooo, uninstall ALL National Insturments stuff (I had like over 500 and it took about 40 min) and install fresh! hope it helps! Good Luck!
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 08-01-2012, 23:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Tried again and it worked. Must have been something screwy with the school computer. Now if only I could get the simulator game working on school computers.
