Re: HiGrip wheel
The HiGrip wheels seem nice. They're lighter than the 6" plaction wheels on AM by 38% (.5lb each as opposed to .81lb).
A google search for TPU Rubber wheels went nowhere. Is there any indication that it will be offered in larger sizes? Smaller sizes? |
Re: HiGrip wheel
The size of the wheel does not necessarily keep you from going over the bump. Just build a slippery ramp in your chassis in front of your wheel so you slide up and over. That being said, we are using 8 inch wheels.
Bruce |
Re: HiGrip wheel
We played with them a bit. I'm not certain that they'll see use on 2815's robot this year (in COTS or modified form), but they do look like an upgrade over prior designs with the divider as it is.
Teams I've been on have used variations on modern kit wheels for several years with no issue on the spokes. If we chose another wheel, it wouldn't be on that. |
Re: HiGrip wheel
Our Team was in two Regionals one at Medera, CA, Central Valley Regional and the last in San Jose, Ca, Silicon Valley Regional. Our 6' HiGrip KOP Wheel worked great in the first regional. While we at the second Regional the Janksters, Team 1976 reported that they had a wheel failure and ask us to borrow a wheel. However, we did not have a spare wheel. We took a look at our wheels and fould a broken spoke on a rear wheel. Upon further investigation we noticed the wheel was split across the tread. We did not have enough time to change this wheel until the next match. Thank you 2144 for giving us a wheel. The Janksters broke two wheels at SVR. I will not use these wheels next year.
Re: HiGrip wheel
And two competitions on a single set--back when I was a student on a team, we could go through two sets of AM and McMaster wheels in an event, minimum one set. We'd usually take some time on practice day to change out from the previous event, wear through the wheels by the end of elims if not before, go to the next event, repeat. (We'd also buy quite a few spares.) You guys put a ton of drive time on those wheels, so I'm not terribly surprised that they would have broken eventually--fatigue plus impact will take down quite a few things, let alone a wheel. |
Re: HiGrip wheel
Thanks for the quick response. Like I said two teams at SVR had problems with these wheels. Our team 2643 and 1976. Team 1976 was paired with 254 and 118 to win SVR. But they broke two wheels. Yes, I am waiting to hear from Andy Mark. These wheels seem to be pretty grippy. But I think the drive train can over power the cross section.
#7
Re: HiGrip wheel
Here is an example... http://youtu.be/048HHG8m6A0 Thanks to the 3-4 teams that loaned us wheels (the team didn't think the wheels would break and didn't pack any extras), including 692, 3933, 3482?, and others! |
#8
Re: HiGrip wheel
We broke 5 at the Sacramento, Andy Mark replaced them. Had no problem at CVR. We did get hit pretty hard when a nameless team ram us as we were tipping over. They have some bad reviews on the AM site.
#9
Re: HiGrip wheel
During the past two weeks, 3 teams have contacted us regarding some durability problems with these wheels. I have recently talked to one team today who had broken wheels at SVR. This is the same wheel that was used in 2012, with the same HiGrip tread. The only difference is that the tread is colored white this year. In 2012, we did not receive complaints regarding the durability of these wheels.
From my experience at regionals this year, there is much higher speed being reached by the robots in this open playing field. Robots are hitting each other at high speed within the field, and there are not field barriers (steps, etc.) present to slow them down. During these collisions, the wheel is getting a high side load. Combine this side load with a high tractive force of the wheel, and we have high stress on the wheel bore, spokes, and rim. We have a short term and a long term plan to fix this wheel.
Sincerely, Andy Baker President AndyMark, Inc. |
#10
Re: HiGrip wheel
FYI, here's a picture of the wheels team 1967 broke at SVR.
The one on the right broke in match 28 and prevented us from driving. The middle one is not fully broken yet but has cracks on the spokes where they meet the outer rim so we replaced it. The one on the left broke in the elimination matches and we could still drive because every spoke completely broke so we were driving with 5 wheels. Overall, we're very happy with the belt drive system, but this year we're able to drive much more aggressively than in the past due to the field and due to our robot having a much lower CG. So, while I think we've never seen anything like this (and we've used these wheels in the past), I also think we're abusing the wheels much more than in past years. We're definitely considering metal wheels for next year already! And, we're ordering spares for the championships (which we're VERY excited to be able to attend)! |
#11
Re: HiGrip wheel
Oops - I hadn't realized Alvin had already posted a picture. Sorry for the repeat.
#12
Re: HiGrip wheel
Does anyone know what the Coefficient of Friction for the HiGrip Wheel is normal to the direction of travel? I know AnyMark has 0.95-1 listed as the coefficient of friction for the wheels; however, I don't know if that is for the direction of travel exclusively or both.
Or is there an effective coefficient of friction due to the "biting" in the carpet normal to the direction of travel? Essentially in an equation what do I use for Mu_x (direction of travel) and Mu_y (normal to direction of travel)? **A bit off topic from what the OP has started** |
