Go to Post We do FRC to inspire and to be inspired. - Basel A [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 08-01-2012, 18:30
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Air Defense System
Originally Posted by gyroscopeRaptor View Post
Are there any videos of teams attempting this from 06?
Not that I know of because as I said, no teams attempted it in competition. There was a similar thread on Delphi back then, but for most it never made it past the concept stage, and the teams who prototyped it found it wasn't working as well as they wanted.
Remember, the balls are going to be traveling at a relatively fast rate of speed. In order to change their momentum, it will take a lot of work. If you think of physics W = f * d, you'll need a considerable force (f) for such a short distance (d) window. If anyone wants to pursue this, most certainly don't let me stop you. However I would suggest that no one put all their eggs in this basket, as it may not work out as well as you'd hope. Good luck!
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 08-01-2012, 18:32
Rocketeeringer's Avatar
Rocketeeringer Rocketeeringer is offline
FRC #0020 (The Rocketeers)
Team Role: Communications
Rocketeeringer is on a distinguished road
Originally Posted by Chickenonastick View Post
What would you use to generate an updraft?
pneumatic cannon, i think fans are illegal under Robot 4.1.8 Motors and Actuators,
or maybe a vacuum, that is exempt
Unread 08-01-2012, 18:35
Thanks! We'll keep that in mind, after posting reading these responses I'm having doubts about its effectiveness but we'll still try it on the side
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
If you switch out the motors on a vacuum or fan you could use it.
Every day is a new adventure!!!
Unread 08-01-2012, 18:37
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
We are allowed 22 motors this year...
FRC 115 MVRT: 2008-2011 (Mechanical Director)
FRC 3504 Girls of Steel: 2011-???? (Mentor)
Unread 08-01-2012, 18:38
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Indeed we are. I guess i don't see your point?
Unread 08-01-2012, 18:40
Billfred's Avatar
Billfred Billfred is online now
I think blayde is trying to insinuate you can throw multiple motors at a hypothetical vacuum/fan solution.
At the same time, I'd say the free speeds of many of those motors would make them unsuitable for the task (consider the copious amounts of window motors in the mix).
Unread 08-01-2012, 18:41
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
This seems very difficult with the tiny air compressor and limited battery life. I fly lots of quad copters and even the huge amount of wind a 10" prop at significant RPM puts out with a brushless motor wouldn't make a huge impact on the ball at 3'
-Mike
Unread 08-01-2012, 19:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Fans are not illegal, please quote where you thing they are.
A pneumatic cannon would be difficult with the small valves we use.
Unread 08-01-2012, 19:17
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
I do not see anything in the rules that would directly prohibit a team putting a swamp-boat esque shrouded fan powered by a cim on the top of their robot pointing directly up (or at an angle maybe 20 degrees from vertical). A 20" diameter fan powered by 2 cims would be.... scary. Possibly effective, but i'd have to see a prototype. As a hunch though, i'd say it'd be very effective at blocking the middle tier goals, but probably ineffective at changing the path of balls aimed at the top tier goals (unless you're right in front of the robot lobbing for the top rung and can impact the balls motion right as it leaves the robot)
D5 Robotics: Member since 2007
Drive Team Coach, Design Mentor
Palmetto Regional attendee 2007-2011
2009 QF, 2010 SF, 2011 SF
Unread 08-01-2012, 19:21
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
You don't want it to point up, you want it to point slightly to one side. Pushing the ball up may not cause a miss (it just falls into the basket from a higher point). Pushing the ball to the side will disrupt the intended trajectory in both azimuth and elevation, and make it more likely to miss.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 19:26
Pointing it up could actually assist the ball into the hoop if you're unlucky
Unread 08-01-2012, 20:02
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
So instead of air, uses balls as SAM's (Surface to Air Missile).
Software Mentor
3853 Pridetronics[
Unread 08-01-2012, 20:06
Ninja_Bait's Avatar
AKA: Jake Potter
If you can hit a ball with another ball, you should:
a. work for NASA and:
b. use your impressive engineering and programming skills to make a killer offensive robot instead of a defensive one.
Unread 08-01-2012, 20:10
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Also, pushing the balls up may likely push them out of the court, incurring a foul under <G13>.
This makes any uber-fan idea flawed, IMO.
