Go to Post I think they get nutrition from chain greese. - Lucid [more]
Unread 08-01-2012, 19:57
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Field Drawing Question
I cannot find the dimensions for the Polycarbonate used to cover the low cost bridge. It is listed in the parts list of the bridge, in the team drawings (http://www.usfirst.org/sites/default...mDrawings.pdf). It is item 11, GE-12095 but that part number never shows up anywhere else in the document. Does anyone know where to look?
Thanks,
- Alex
Unread 08-01-2012, 20:01
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: Field Drawing Question
You can find GE-12095 in the Game Specific Drawing document, not the Team Drawings one.
It seems to be 80 inches long by 48 inches wide.
(FYI, TE means it's in the Team Drawings document, while GE means it is in Game Specific Drawings)
Unread 08-01-2012, 20:46
lemiant's Avatar
the Dreamer
AKA: Alex
Thanks so much, that makes a lot of sense!
Unread 08-01-2012, 20:51
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
The dimensions of the top of the bridge are 44" x 88".
Unread 08-01-2012, 21:36
Rocketeeringer's Avatar
Rocketeeringer Rocketeeringer is offline
FRC #0020 (The Rocketeers)
Team Role: Communications
Rocketeeringer is on a distinguished road
Arena 2.2.5 "Each Bridge is 48 in. wide, 88 in. long (outside dimensions)"
Unread 08-01-2012, 21:58
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
There is a slight difference between the specifications for the Team-Built bridge and the Official Bridge. The Team-Built bridge top is 88 by 48 in. while the Official Bridge top is 88 by 47 in. The Official Bridge has an aluminum side barrier that takes it up closer to 48 in. wide, but the surface is only 47 in. wide.
Both bridges use the same surface of a sheet of 1/8 in. thick polycarbonate which is 88 by 47 in. This is found on Drawing GE-12095 in the official field drawing set available on the usfirst.org web site.
Dr. Bob
