Go to Post however, if i tried it i would probably end up setting my hair on fire - Henry_Mareck [more]
Unread 08-01-2012, 21:00
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
FOR EVERYONE HAVING USB CORRUPTION AND DISK READ ERRORS
1. DO NOT CHANGE THE BOOT ORDER. This is the reason for your problems.
2. On the 2GO screen, hit the F11/F12 key on your keyboard, and select the USB to boot.
3. It should work.
We had the same issue, until we figured out that changing the boot order was the source of our issues. Just change the boot order back to the HDD being first, and follow the instructions above.
If you have any questions, just ask.
-Eagle Engineering 1138
Unread 08-01-2012, 23:40
vladsfl vladsfl is offline
FRC #3992
vladsfl is an unknown quantity at this point
Re: FOR EVERYONE HAVING USB CORRUPTION AND DISK READ ERRORS
We tried it both ways... USB key does not seem to show up when I hit F11 ...
Also tried to plug in USB key on every computer I have and none is recognize it
Unread 08-01-2012, 23:48
Team 1138
What are the different options you have when you hit F11/F12?
