Go to Post I guess everyone cant play real defense, like actually pushing the other robot instead of ramming it with the intent to destroy. - Dillon Compton [more]
Unread 08-01-2012, 21:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
How many of you are actually being a feeder bot?
Honestly, the overwhelming number of people on my team chose that they want to be a feeder, but my issue is that if our small sample does, in fact, reflect the general population, we are in deep trouble. There might be a lot of to be shooters that will be converted to feeders during competition. Anyone have any input on whether a team should actually try being a feeder full time? I honest to God doubt our team's capabilities in manufacturing an accurate, consistent shooter. If my team can pull off a consistent shooter, I'll get onto the basket boat in a heart beat, but I am staying far from it for now.
Unread 08-01-2012, 21:08
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: How many of you are actually being a feeder bot?
It seems as though a robot designed around reliable shooting could easily transition to be a facilitator/feeder/defense-when-there-aren't-balls bot if all of the other robots functions perform well other than consistently accurate shooting. So by designing around the strategy to score well, and then failing to score reliably, I think a team could have themselves a VERY good feeder bot. There would probably be some advantage to designing around that strategy from the get go, but we shall see.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Well, like you said, lots of teams will go for feeders as they probably won't be very accurate. Thus, going completely feeder in my opinion isn't the best plan. This would almost be the same as going completely defensive last year. Where all bots could do it, but some where designed for just defense.
Feeders will be VERY useful this year though due to the issue of human players not throwing during the entire match and only during the end. Thus, we do need feeders but going 100% feeder still may not be the best idea.
UNLESS, you came up with a design to just sit in front of the drop and the human player could just drop balls in constantly and you throw them over with a launcher of sorts. This would be very useful and give the rest of the alliance valuable scoring time.
So, in my final opinion, I believe if you do a feeder correctly it is definitely worth doing 100%. Teams will pick you in finals do to your convenience and time saving. Though, if you do it wrong and it takes too much time for you to get set and can't launch the balls to where the are needed, you probably won't be chosen for finals.
Unread 08-01-2012, 21:13
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
My argument against that was the fact that we would allocate such a big chunk of our time with the camera and projectile path predictions and ect. I want to focus on a dynamic system for balancing the robot. I want to perfect that. Having designed as a feeder will let us forgo the "storage" area and just chuck the balls across the field as soon as it gets picked up. (The shooter is on a turret.)
Unread 08-01-2012, 21:14
Andrew Lawrence
Posts: n/a
We will be offense, defense, feeders, and everything else. We have something that is in my opinion the best design ever! (Not just because I made it.)
Unread 08-01-2012, 21:16
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Couldn't a dynamic system be "put this accelerometer on the robot that, when activated, will take control of the drive at a slow speed until it reaches equilibrium"?
Unread 08-01-2012, 21:19
DjMaddius's Avatar
AKA: Matt Smith
Balancing wont be as difficult as you think I believe. Check this out, its impressive:
http://youtu.be/-AMaqqmoLgQ?t=1m27s
Unread 08-01-2012, 21:20
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
But what good will that serve when trying to balance 3 bots? I wrote this before, but a weight shifting mechanism where all the electrical components and the shooter mechanism is on a platform which is then shifted from the front to the back of the robot. Will have to test if that will be enough to tilt the bridge in the middle and if there will be enough room on the robot for such a platform to move enough to change the center of gravity.
And I would use a gyro and not an accelerometer.
Unread 08-01-2012, 21:27
MountainFreak MountainFreak is offline
FRC #1629 (Garrett Coalition (a.k.a. GaCo))
MountainFreak is an unknown quantity at this point
Well if u were planning on just being a feeder bot u might just want to try make a mechanism that will score in the lowest hoop and then consequently would feed very well.
Unread 08-01-2012, 21:28
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That was what we called a "plan B", but I really doubt its effect. I mean the same mechanism that can chuck a ball 50 feet can really score even at 2 feet? Highly skeptical on that being a viable option.
Unread 08-01-2012, 21:33
AKA: Carl Springli
Any time you score, you put balls into the hands of your opponents. That means that if you score 1 point on a ball, then the same ball is given to your opponents and they score 2 or 3 with it, you come out behind on that action of scoring the one point. It may be more valuable to simply forward the balls to your offensive robots.
Unread 08-01-2012, 22:56
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
My team has decided that we will focus on being a shooter first, and then if we have to, a feeder (sitting one our side of the barrier and firing across the field.)
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 08-01-2012, 23:10
MohammadAdib MohammadAdib is offline
Outside-of-the-box thinker
FRC #0948 (NRG948)
MohammadAdib is an unknown quantity at this point
My team (not necessarily me) is thinking of a robot that is purely defensive. They assumed that most of the robots are going to be offenders and hence went with a design where the balls are caught in a net and then somehow are thrown back to our alliance robots...definitely not the best idea, i agree
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We haven't decided yet, but my opinion is that your feeding mechanism should be your plan B if your scoring isn't working out. You can always feed if you have a method of shooting balls. If your feeding system doesn't work out, you have nothing.
Unread 08-01-2012, 23:15
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That is what the other side's argument is, but IMHO. To have a shooter, we would be investing so much time and weight into it. For a feeder, the only actuation you need of the shooter is the yaw. But for the actual shooter, you need both the yaw and pitch. Is that extra weight worth it if we will just go feed? Is the extra time getting the imaging system and everything worth it if the shooter is only that accurate? I would rather have spent my time perfecting the balance (and apparently, the robot does NOT need to be fully supported, will have to ask GDC about that) and have 3 robots balance. Also, because of the simplicity, the feeder mechanism will not break as much as a fully actuated shooter.
Keep in mind that your strategy opens you up to a lot of penalties. The opposing robot only needs to TOUCH its safezone and touch you. There is a penalty right there. But eventually, the opposing team might get DQ for intentionally doing that.
