Go to Post I voted to keep Stop Build Day but only for students. Mentors get to keep working on the robot. - marshall [more]
Unread 08-01-2012, 12:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Official 2012 Motors Models and Specs Thread
I wanted to create this thread as the place to discuss all the different motor possibilities for 2012 including the new motors in the kit of parts, and the plethora of motors available to us through the junkyards participating in the auto recycler network. Near us, the local Pick Your Part participates. That would be rather interesting if we could go get whatever motor from whatever car.
What make and model of car has the most powerful motor in its doors, seats, wipers, and windows?
Unread 08-01-2012, 16:00
Re: Official 2012 Motors Models and Specs Thread
Does anyone know if there is a link to an online PDF of the ARA PDV ?
Unread 08-01-2012, 16:41
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Wiper motors and window motors will not be as strong as seat and door motors.
The vex motors and throttle motors are, uh, interesting? I'm most excited about the PG71. Hopefully it will be more reliable than the banebots 775/planetary. Also, the pg71 planetary can be bought separately, as can the adapter plate for 500 sized motors and the 1/2 inch shaft adapter.
Unread 08-01-2012, 17:46
The PG71 and the RS775 are not even in the same league. The 775 is 271 watts max, and the PG71 is 21 watts max.
Unread 08-01-2012, 18:04
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
That is with the gearbox, without it is 180 W, as a reference the 775 is about 100w more! not 250...Still a big deference between a motor of the exact same size/look!
2011 Record (11-3-0)
Unread 08-01-2012, 18:05
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Specs on the PG75 from AM
Performance Specs:
Voltage: 12 volt DC
No Load RPM: 84 rpm
No Load Current: 1.3 amps
Maximum Power: 130 Watts
Stall Torque: 6.8 ft-lb (at 11.6 volts)
Stall Current: 11.3 amps (at 11.6 volts)
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 08-01-2012, 18:07
Could you please post a link to your source for this data. Thank you.
Unread 08-01-2012, 18:12
Performance Specs:
Voltage: 12 volt DC
No Load RPM: 84 rpm
Read posts 4, 5, 7, and 8 of this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=99390
Unread 08-01-2012, 18:41
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Performance Specs:
Voltage: 12 volt DC
No Load RPM: 84 rpm
These numbers, posted by me on the AM website two days ago, are not correct. They have been updated to much more realistic, and larger numbers. We at AndyMark are changing these numbers a bit after some further testing this weekend. Sorry about this change. Please check our PG71 web page for any further updated information.
Here is more to the story.
When I was updating the web page for this motor on Friday, getting it ready for Saturday's kickoff, I saw that the stall torque was listed at 11 amps. This is information we got from the manufacturer. So, I called Mark, who was out at Manchester for kickoff to see what was up with this. He created and interpreted the performance numbers a few weeks ago, and listed the stall torque at 11 amps. We both thought about this some more and agreed that was waaaaay too low. He got home today and did a bench test that repeatedly performed at these numbers below. This test was ran with a 12.8 volt battery providing voltage directly to the motor. The stall torque is 23 ft-lbf, and the max current reading is 28.6 amps. We believe this translates to approximately 350 watts as the max power for the motor.
Tested at 12.8 volts
23 ft-lbf max torque at stall
28.6 amps pulled at stall
Estimated 350 watts of power
Here is Mark's setup. He had a force gauge measuring an arm's pull at exactly 1 foot away from the motor. The force gauge showed 23 lbs of force and the amp meter showed 28.6 amps. It was a simple setup, and we ran it about 10 times. The numbers were consistent. These numbers make much better sense to me compared to the "11 amp stall torque" numbers I posted on Saturday.
Again, sorry for these erroneous numbers yesterday, and please check out the PG71 website for future updates.
Sincerely,
Andy Baker
Unread 08-01-2012, 19:12
The numbers don't seem to add up. Using the 84 rpm free speed from the AM web site:
At 12 volts:
stall torque = (12/12.8)*23 = 21.56 ft-lbf
Assuming max output power occurs at half stall torque and half free speed:
half stall torque = 21.56/2 = 10.78 ft-lbf
half free speed = 84/2 = 42 rpm
max watts = 42*10.78*0.142 = 64.3 watts
At 12.8 volts:
free speed = (12.8/12)*84 = 89.6 rpm
half free speed = 89.6/2 = 44.8 rpm
half stall torque = 23/2 = 11.5 ft-lbf
max watts = 44.8*11.5*0.142 = 73.2 watts
Unread 08-01-2012, 19:57
here is the official FIRST data sheet, might it also be incorrect?
http://www.usfirst.org/sites/default...r%20Info_0.pdf
the am-9012 is the base motor and the am-9014 is the motor with the gearbox...
Unread 08-01-2012, 20:40
Not according to the AndyMark web site.
What is your source for this information?
Unread 08-01-2012, 20:57
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
http://www.andymark.com/product-p/am-0914.htm
http://www.andymark.com/product-p/am-0912.htm
The PG71 gearmotor is AM-0914 (quoted on First's data sheet in the above link as having an 11.3 amp stall current)
The 9015 motor is AM-0912
It looks like the First document has the same misquoted figures for AM-0914
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 08-01-2012, 21:14
I should have been clearer. The point in contention is this: Timz3082 is claiming* that the motor portion of the PG71 (am-0914) is the same motor as the 9015 (am-0912). I was asking where he got that information.
* see post #5: "That is with the gearbox, without it is 180 W"
Unread 08-01-2012, 21:34
Sorry, I was misinformed, upon further examination, the other motor is infact a different motor. The one without a gearbox is rs550 sized, the one on the gearmotor is rs775 sized, sorry about that, the person who inventoried our kit must have made a mistake.
