Go to Post It's always FIRST season. - Foss@Team176 [more]
Unread 08-01-2012, 16:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Wheel Size?
Originally Posted by the man View Post
Did some one say segway bot?
Yeah, there was a segway bot sketch made by one of the younger mentors during the kickoff....
Of course the discussion deteriorated to a unicycle robot.
There should be no limit to the size of wheels you can use besides the 38" limit, but think about how tippy the robot would be with larger wheels.
Unread 08-01-2012, 19:59
I LOVE ROBOTS!'s Avatar
I LOVE ROBOTS! I LOVE ROBOTS! is offline
KING TRIDENT! MASTER OF TMACILAC
AKA: dakota ewigman
FRC #1730 (Team Driven)
Team Role: CAD
I LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to all
Re: Wheel Size?
Originally Posted by PayneTrain View Post
I don't want to rain on your parade, but they couldn't possibly be any larger than 36 inches in diameter if you plan on building a 28x38 inch frame around them.
someone forgot about putting the wheels in diagonal. so find the hypotenuse, then that's accurate.
Unread 08-01-2012, 20:02
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Wheel Size?
44.407in with a frame made of 1in on a side.
Every day is a new adventure!!!
Unread 08-01-2012, 20:04
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Wheel Size?
We have successfully gone from the realm of intelligent engineering to the realm of infeasible, useless number mashing.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 20:05
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Wheel Size?
Oh come on now. Impractical at worst.
Unread 08-01-2012, 21:19
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Wheel Size?
Originally Posted by ratdude747 View Post
I remember seeing an old 2004 clip on youtube with a bot that used them to climb the stairs...
That was 1218 The ChaBots. They made it all the way to the Einstein Final that year. They were pretty hard to stop, even if you dropped a robot on them.
Robot Inspector
Unread 08-01-2012, 21:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Wheel Size?
The frame perimeter would be at ~2-10 inches. the largest part of the wheel will be at .5*wheel diameter. In other words, the frame itself has no effect on your maximum wheel size, the vertical projection of your frame perimeter is the limiting factor. that means that a wheel with a tapered tread (allowing it to extend into the corners of the frame perimeter) could be up to 47.2 inches in diameter if it were placed on a diagonal, despite the ridiculousness of such a configuration. Assuming a frame 10 inches off the ground, the wheel, at frame level would measure only 29.1 inches. by lowering the frame to 2 inches from the ground, that number drops to 13.6 inches.
In a far more conventional long setup. 38" wheels would measure only 25.7 inches at a height of ten inches and 12.2 inches at a height of two inches.
If engineers can't say what if, then the world would be a much more boring place. That being said, once wheel diameter gets a little higher than ten inches, making them any bigger would yield a negligible advantage. And that is ignoring the added weight of the larger wheels and the extra gearing needed to bring the motors back into an operating envelope which the electrical system can cope with (without browning out every time you try to turn).
Unread 08-01-2012, 21:27
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Wheel Size?
Slightly irrelevant, but I remember a team that had a large gear dropped on their robot during shipping. That would suck.
Unread 08-01-2012, 21:33
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Wheel Size?
340 also had them on Einstein in 2004.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 08-01-2012, 23:01
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
Re: Wheel Size?
Originally Posted by Apeace View Post
I just noticed that the rule book has no mention of the wheel size constraints. Any thoughts?
Wheel size constrains how easy it is for your robot to turn. I was a little surprised, but with these wheels on our off-season robot we could do nothing but move backwards and forwards on tile/ carpet.
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 08-01-2012, 23:05
MrForbes's Avatar
AKA: Jim
Re: Wheel Size?
It's not the size of the wheels, it's the layout....they are spaced far apart front-back, not far apart side-side, and they have good traction.
Unread 08-01-2012, 23:28
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Wheel Size?
that wasn't it.
maybe.
IIRC the clip was from a regional, may have been a qualification...
Unread 10-01-2012, 20:56
scree0114 scree0114 is offline
FRC #3642 (Huskies)
scree0114 is an unknown quantity at this point
Re: Wheel Size?
would omni wheels be better than the wheels they give you in the kit?
Unread 10-01-2012, 23:28
Apeace Apeace is offline
FRC #1123
Apeace is an unknown quantity at this point
Re: Wheel Size?
I think it all depends on how you lay them out. You could do a skid drive, which is where you have 6 wheels, and the center two are the KOP wheels while the outer four are omni wheels. That way, you could spin on a dime.
