Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Unread 08-01-2012, 20:49
bhaidet's Avatar
bhaidet bhaidet is offline
FRC #0435
bhaidet is an unknown quantity at this point
"assisted" balance
As teams balance on the alliance bridges, they (or at least their bumpers) will likely touch the side wall. I would not expect this to disqualify a team from being "balanced" but then it brings up the slippery slope question. How much contact is legal? would <G10> prevent you from, for example, attaching a suction cup to the court wall and using a piston to lift yourself vertical?
This example is probably illegal, qualifying as "attaching" to an arena structure, but what about something that just presses against the wall, like a pneumatic piston with racquetball-type-material on the end? It would be easy to stick this into the wall while the platform was tipping and with timing, sticking yourself at horizontal.
Unread 08-01-2012, 21:27
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Re: "assisted" balance
There is only a small lip on the outside perimiter of the ramp, no wall. Look at http://www.youtube.com/watch?v=-AMaqqmoLgQ.
Unread 08-01-2012, 21:35
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
What if instead of pushing the wall, you extended over the side of the bridge and used a pneumatic to press on the floor and hold the bridge level through the end of the match.
(assuming bridge would fall if your robot wasn't pushing it balanced)
Any ideas on the legality of this?
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 08-01-2012, 21:36
Andrew Lawrence
Posts: n/a
That's what we thought about.
Unread 08-01-2012, 21:38
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Going with Steven's post, has anyone found what it means to be balanced on the bridge? I know the bridge has to be within 5 degrees of horizontal, but what can your robot be touching? the ground? the side wall? the bump?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 08-01-2012, 21:43
Snorlax Snorlax is offline
FRC #3229
Snorlax is an unknown quantity at this point
[G41] If a Robot from each Alliance is balanced on the Coopertition Bridge when the final score for a Qualification Match is assessed per Rule [G37], each Alliance earns 2 Coopertition Points. If the Coopertition Bridge is not balanced, but a Robot from each Alliance is fully supported by the Coopertition Bridge, each Alliance will earn 1 Coopertition Point.
I don't think the rules explicitly state what balanced is defined as.
Unread 08-01-2012, 21:47
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
The coopertition bridge under [G41] requires robots to be fully supported by the bridge. I am under the impression that the GDC forgot to mention the condition of being "fully supported by the bridge" for alliance bridges' balancing. This should be up for Q&A when it opens to get the actual word.
Unread 08-01-2012, 21:52
Aren Siekmeier's Avatar
on walkabout
Aside from the rule concerning attaching to field structures, there is nothing saying you cannot touch anything other the ramp to count as balancing. For instance, the floor. The same is true for coopertition bridges (for which you only have to be fully supported if its NOT balanced and you still want the 1 pt).
The current definition of balanced is within 5 degrees of horizontal. Nothing more.
Unread 08-01-2012, 21:53
pfreivald's Avatar
AKA: Patrick Freivald
The rules explicitly state that a bridge is balanced if it is within 5 degrees of horizontal.
...that said, I'm willing to bet that a rules update will clarify that to earn points, robots must be only in contact with the bridge and/or other robots that are only in contact with the bridge. Remember, read the rules as engineering guidelines, and do not try to "lawyer" them.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-01-2012, 01:39
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
What if two robots are completely on a bridge and fully supported by the bridge and/or themselves, while a third robot is on the carpet but holding the bridge level by pressing up or down on one end of the bridge? Of course, this probably breaks the intent of the rule, but this needs clarification.
Unread 09-01-2012, 21:57
lefkoc lefkoc is offline
FRC #0195
lefkoc is an unknown quantity at this point
I'm not sure on touching the floor, but my team also wondered if it was legal to clamp onto another bot on your alliance (not the opposing) to make it easier to put the third bot on the bridge.
Unread 10-01-2012, 16:53
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
I see no rules against it, but it will be a week before I feel thoroughly studied up.
Unread 10-01-2012, 17:17
bhaidet's Avatar
FRC #0435
I feel like the 3rd robot touching the floor would be completely legal but would only count as two bots.
My original pneumatic ram would be pressing against the side fence for the arena, not the floor. I'm sure any clarification will outlaw the floor or else all 3 bots could just go stand next to it and touch it
Unread 10-01-2012, 17:25
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
The first team update says:
A Bridge will count as Balanced if it is within 5° of horizontal and any Robots touching it are fully supported by it.
Emphasis mine. While I think it was clear that this was the initial intent of the rules, now the intent matches the rule itself. No touching the ground!
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 10-01-2012, 17:29
LabVIEW Rocks!'s Avatar
LabVIEW Rocks! LabVIEW Rocks! is offline
FRC #1778
LabVIEW Rocks! is an unknown quantity at this point
Im pretty sure you can grab an alliance robot, but not an opponet robot. But be sure and read the rules carefully first.
