Go to Post Chuck Norris can be the human player and throw a Poof ball into the 3 point goal and it counts. - Andy Baker [more]
Unread 08-01-2012, 22:25
shank948 shank948 is offline
VP of Programming - 948
AKA: Stephen Shank
FRC #0948 (NRG (Newport Robotics Group))
shank948 is an unknown quantity at this point
How to Program Swerve in Java
I currently don't have access to wpi library. In the 2012 RobotDrive class, is the swerve drive method designed to be used with one motor for each wheel?
Unread 08-01-2012, 22:27
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: How to Program Swerve in Java
I'm sorry I do not have a programming answer for you, but yet a design question. Do you have any prior swerve experience in both construction and programming?
Unread 08-01-2012, 22:28
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
There is no swerve drive class. You have to write it yourself. Mr. Ether has a great white paper on it. http://www.chiefdelphi.com/media/papers/2426
Unread 08-01-2012, 22:30
AKA: Stephen Shank
I've been programming on the team for the past two years, but I have a basic understanding of construction. What's your question?
Unread 08-01-2012, 22:32
AKA: Stephen Shank
Wow thanks. I could program it, but I was wondering if there was an easy way. This will be a great help.
