Go to Post There's no finer engineering than pit engineering. - kaszeta [more]
View Poll Results: What are you programming in?
Java 65 37.79%
C++ 48 27.91%
LabView 56 32.56%
Other (IDK what you could possibly be doing...) 3 1.74%
Voters: 172. You may not vote on this poll
Unread 08-01-2012, 22:25
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
I just wanted to know what everyone is actually programming in so we can get a good idea on which language is more used..
Unread 08-01-2012, 22:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: What are you programming in?
Java.
Unread 08-01-2012, 22:27
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
C++
Unread 08-01-2012, 22:28
Team 1138
C++
Unread 08-01-2012, 22:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
For "Other", there is Python, and LUA. Not sure if they are still being updated.
Unread 08-01-2012, 22:37
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
LabVIEW all the way.....
Kettering Motorsports
Unread 08-01-2012, 22:39
Team 1138
Why does everyone like LabView??
We use C++ and it works great, what's the difference???
Unread 08-01-2012, 22:41
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Labview is graphical and C++ is text based. Java is also popular because most of the kids learn Java in school because the AP test is in Java.
Unread 08-01-2012, 22:42
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
LabView is a graphical programming language, C++ is text based. LabView tends to be easier for people with less experience to pick up. That said I'm using Java. Java and C++ are quite similar, however C++ is lower level, and a bit more difficult for new programmers.
Unread 08-01-2012, 22:47
apalrd's Avatar
More Torque!
VRC #3333
Having programmed in a multitude of languages (including LabVIEW, C, Matlab, Simulink, and Perl) I could use either C++ or LabVIEW to accomplish the task with about the same amount of effort on my end. I've always thought that C++ and Java are the same for what we are doing (all of the higher-level features of Java don't help us), so it's personal preference between the two.
That said, LabVIEW provides a much nicer debugging interface, and the real-time front panel is just awesome. It's super easy to change stuff and look at graphs and data without doing anything in code.
C++ and Java are both textual, C++ is procedural or object oriented, Java is object oriented. LabVIEW is a data-flow language, so it represents code as the flow of data and operations happening to the data, which is quite easy to understand.
Unread 09-01-2012, 09:26
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
We are doing a build in 2 languages.
Python and LabVIEW. I have much experience with Python over the years and it looks like it could be interesting. Having a different point of view on programming issues will help get past them quicker. Doing two languages will help us code quicker and better.
Unread 09-01-2012, 09:57
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Java
Unread 09-01-2012, 10:28
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
LabVIEW
~Team 1529 Cybercards~
Unread 09-01-2012, 10:29
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We simply use LabVIEW due to the ease of use, abundance of debugging tools, and the quick speed of development.
Being able to probe and trace values while the code is running really gives the students the ability to understand what their code is doing.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-01-2012, 12:56
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Java. Simple and Object Oriented. Plus since most of our programmers have never programmed Java is a great starting point.
