Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Unread 08-01-2012, 22:37
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Collector material
My team is currently designing/prototyping a belt/roller system to collect the balls. We are looking at some of the '09 bots for roller materials, but I was wondering if other teams could give us some feedback on materials and their pros and cons.
the roller itself: We plan to use PVC, and make some sort of hub.
Grip material: I really am not sure what to use. We're considering polycord, hockey tape, pool noodle, maybe banebot wheels... I'm really need suggestions on how to do this; I don't have much experience with many of these materials. Also, are there different types of polycord we need to look into? (I think we have orange solid polyurethane from 2009 that we can weld together with a heat gun)
Other suggestions? Let me know if you think we are going about this wrong.
Thanks,
Alex
Unread 08-01-2012, 22:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Collector material
We've used wedgetop "tread" like is used on wheels. McMaster Carr sells it as conveyor belting.
also, instead of PVC, try ABS sewer pipe, it weighs less and won't explode. We had a PVC ball collecting roller explode in 2006 when another robot ran into ours
Unread 08-01-2012, 23:42
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
If you have the resources you can take ABS tubing 2"OD and 1"ID and lathe it with poly cord grooves and a R8 ball bearing press fit groove on either end. We did this in 09 with our conveyor system.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 08-01-2012, 23:59
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
http://www.mcmaster.com/#standard-co...-belts/=fq414g
That?
Unread 09-01-2012, 00:25
MrForbes's Avatar
AKA: Jim
Hmmm....doesn't look the same as it did a couple years ago. Interesting. They used to have the same stuff that IFI and AM offer as "Wedgetop tread"
Unread 09-01-2012, 00:51
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Great thread from 2009 discussing the use of polycord in 2006 and how to use it...LOTS of useful information!
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 09-01-2012, 03:03
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
If you're going to use the polyurethane (which I'd recommend, we've used it in two robots past) make sure you get the hollow tube material, not the solid cylinder. The pipe material comes with metal barbs that can fasten two sides together, whereas the solid core material must be melted together. Just a suggestion.
Here's a link to a really good thread to peruse at your leisure. It basically discussed the merits of polyurethane tube belts.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
