Go to Post Being a mentor doesn't have an age requirement. As long as you are positively influencing someone you could be called a mentor and a role model. - EricLeifermann [more]
Unread 08-01-2012, 23:16
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Inconsistent Fender
In consideration of the game, I downloaded the Field CAD that FIRST supplies on the Field specification page. I noticed that there was an inconsistency in the Field dimensions and description as described in the manual:
2.2.4: A Fender is located directly below the Hoops at each end of the Court. The Fender is designed to protect the Hoops from damage by Robots. The Fender is 38-3/4 in. deep by 101 in. wide and measures 8-1/4 in. tall at the front, and 10-1/4 in. tall at the back against the Alliance Wall.
and in the CAD that FIRST supplies:
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 08-01-2012, 23:25
Re: Inconsistent Fender
That piece that is colored differently on the right doesn't belong. It definitely wasn't on the field at the Manchester kickoff. I think ewcp.org has some pictures and video of the official field at the kickoff that should show that piece is "extra".
Unread 08-01-2012, 23:26
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
I haven't seen the CAD before. It appears to be in error. The fender is a two-part structure that has the dimensions you mentioned. Each piece looks like the part on the extreme right of the CAD drawing. There is a left and right part like this one which go together around the chute on the lower goal, but there is not a third one like shown in the CAD.
You can find the specifications in the Official Field drawings on the FIRST web site.
Dr. Bob
