Go to Post In FIRST, there's no such thing as too many 1/4-20 bolts, too many bottles of caffeinated beverage, and too much knowledge from others. - Billfred [more]
Unread 09-01-2012, 00:06
Re: Electrical Solenoid Actuators
Stephen,
The 10 watts relates to the way solenoids are rated. 10 watts at 12 volts is no more than 0.84 amps.
Unread 09-01-2012, 02:15
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
A given solenoid size can dissipate a certain amount of heat. So depending on the input voltage you can operate it at varying duty cycles on a given solenoid.
Take a look at this solenoid's data sheet.
It is rated at 10w continuous duty in all it's configurations. The size of the wire used for the coil determines the voltage vs duty cycle.
Look at the first line using awg 23 wire which gives the coil a resistance of 1.52 ohms.
If you operate it at 3.9 volts it is rated at 10w with a 100% duty cycle.
Operate it at 12.3 volts and it will be rated at 100w and a 10 % duty cycle.
Order it with a 4.01 ohm, 25 awg coil and you can operate at 12.7v with a 25% duty cycle.
Be sure to note the heat sink requirements for the listed ratings.
