Go to Post What's an autonomous mode? - Bill Gold [more]
  #31   Spotlight this post!
Unread 08-01-2012, 21:39
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: The Barrier Thread
If you had 6 inch wheels, you would still be able to drive up the rail like this.
http://www.youtube.com/watch?v=3qWYAOGZVM4
Not necessarily recommending it, but it is using small wheels to drive up a large obstacle.
If one was to use Gates belts, would tensioning them be a problem when the barrier pushed into them?
I think high centering could be a large problem. Could this be solved if you had a convex bottom part of your frame so it had a turtling effect (not stable so it doesn't balance when resting on the frame between the wheels)?
  #32   Spotlight this post!
Unread 08-01-2012, 22:51
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
If anything, it would increase tension, possibly to the point of failure. Technically, this would be a "tensioning problem", but not the one people normally think of, also, it could easily be reduced by adding idlers to the belts where they are exposed so that the belt is pushed into the idler rather than into nothingness.
  #33   Spotlight this post!
Unread 08-01-2012, 23:36
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Anyone thinking of using a 2 wheel robot? I mean huge wheels like 20 or 24 inch bike wheels. I would understand how to keep it upright during operation, but before the match? Little omni wheels to support might help, but will hinder it going over anything.
  #34   Spotlight this post!
Unread 09-01-2012, 00:02
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Originally Posted by Bill_B View Post
I'm looking forward to see what the 6WD fans do for this year.
yeah... after all of the people prototyping WCDs over the break, I wonder too... good luck using 4" wheels to cross the barrier...
  #35   Spotlight this post!
Unread 09-01-2012, 00:08
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Originally Posted by davidthefat View Post
Yep, our 2010 robot broke one of her wheels.
Our team installed aluminum wheels at the front, which were able to sustain the weight of our full-weight robot coming down from the bump.
  #36   Spotlight this post!
Unread 09-01-2012, 00:21
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Our team is thinking of using four or six wheels, and using belts instead of chains. The belts will be backed on the bottom side by a flat panel, so that they can act as tank treads as they go over the barrier.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
  #37   Spotlight this post!
Unread 09-01-2012, 06:35
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
I was thinking something like this: http://www.youtube.com/watch?v=Ktw6AZU2Wtk&t=0m36s whatever drive you'd like+ the threads in front that are shown in this video.
https://kusha.me
  #38   Spotlight this post!
Unread 09-01-2012, 07:24
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
One thing I noticed is the bumper rules this year. If I read correctly the bumpers have to exist somewhere between 2" and 10" from the ground. It seems to me there is only one location for the bumpers if you are trying to cross the bump. The top of the bumpers would have to be at 10" and going down to 5" off the ground. This is the only way that the bumpers won't hit the bump first. As well your frame perimeter would need to clear the bump as well so your wheels are the first thing to hit the bump. The KOP frame assembled with 6" wheels and per the provided instructions will NOT cross the bump even with brute force since the first thing to hit the bump would be either A) the bumpers if the lowest part of the bumper is below 4" OR B) the frame would hit the bump which would be flat vertical metal hitting flat vertical metal. The provided 6" wheels with no extra elevation of the frame would only lift the frame 3" off the ground (actually a little less than that).
Rookie teams please investigate this fully before putting together the KOP frame. You will only create extra work if you don't think about this before hand.
  #39   Spotlight this post!
Unread 09-01-2012, 22:48
Step one: buy a segway. Done
Or you could use the same concept Dean's wheel chair does where it starts on 4 wheels and stands up on 2.
My only semi seriou idea with this is tristar wheels, but I think even that is overkill. http://orionrobots.co.uk/Tri+Star+Wheels
I think my team is plannig to have a ramp at the front of the chassis and actually having a frame with low ground clearance so we slide along the bottom rails of the chassis across the barrier. We think driving six wheels will keep us from getting stuck, and sliding would decrease the impacts and jarring of the robot.
  #40   Spotlight this post!
Unread 09-01-2012, 23:27
pfreivald's Avatar
AKA: Patrick Freivald
This is only true in certain circumstances. It's not difficult to envision a situation where lower bumpers could be used, and yet the bump could still be traversed.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #41   Spotlight this post!
Unread 09-01-2012, 23:36
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Are you thinking of a mechanism that extends past the bumper perimeter, like a foot or a wheel or a wedge?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #42   Spotlight this post!
Unread 09-01-2012, 23:38
pfreivald's Avatar
It would be no fun if I revealed all my secrets...
Team 1551
I write books, too!
  #43   Spotlight this post!
Unread 09-01-2012, 23:39
Ninja_Bait's Avatar
AKA: Jake Potter
Awwww.... shucks.
  #44   Spotlight this post!
Unread 09-01-2012, 23:44
dtengineering's Avatar
AKA: Jason Brett
The last time I saw a mobility obstacle like this was in '04, I believe it was, when robots had to climb a couple of stairs to get up on to a central platform.
There were a number of ingenious solutions including some very nice treaded robots and the occasional one with some pneumatically activated "helper wheels" that would come down and lift the main wheels up on to the step.
But I agree that suspensions might be useful to have, too. I think that might be my first place to look.
Jason
  #45   Spotlight this post!
Unread 10-01-2012, 00:16
ttldomination's Avatar
Sunny
Who said that a WCD has to have 4" wheels?
- Sunny G.
1648: 2013-2014
5283: 2015
