Go to Post Be not afraid, go forth and multiply. - Pat Major [more]
Unread 08-01-2012, 22:00
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Workaround for the Kinect?
I know there have been multiple threads, but I haven't seen (I may have missed it) anyone suggest using a wireless USB.
This particular one uses 5VDC, which would be perfect for the robot. I think I am missing something however? I think it is okay rule wise (as long as we get approved) but will it entirely work on the robot?
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 08-01-2012, 22:05
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Workaround for the Kinect?
<R55>
One D-Link DAP-1522 is the only permitted device for communicating to and from the Robot during the match. All
signals must originate from the Operator Console and be transmitted to the Robot via the official Arena hardware.
No other form of wireless communications shall be used to communicate to, from or within the Robot (e.g. radio
modems from previous FIRST competitions and Bluetooth devices are not permitted on the Robot during
competition).
So, probably not.
Unread 08-01-2012, 22:08
mattiej's Avatar
Programmer Guy
What about this rule? It wouldn't be directly connected to the cRIO
[R67]
Any decorations that involve broadcasting a signal to/from the Robot, such as remote cameras, must be approved by FIRST (via e-mail to frcteams@usfirst.org) prior to the event and tested for communications interference at the venue. Such devices, if reviewed and approved, are excluded from Rule [R55].
Unread 08-01-2012, 22:10
So, what is a decoration?
Unread 08-01-2012, 22:12
mattiej's Avatar
Programmer Guy
I would imagine this it includes everything from LEDs to other cameras, based on the wording of the rule
[R67]
Also in R84
Examples of prohibited wireless systems include, but are not limited to, active wireless network cards and Bluetooth devices. For the case of FRC, a motion sensing input device (e.g. Microsoft Kinect) is not considered wireless communication and is allowed.
Unread 09-01-2012, 03:59
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Having been on a team that actually used a camera on the robot as a decoration prior to the cRio switchover, I can attest to this: they are very stingy about what is considered a decoration, and it appears they have a strict definition of decoration that revolves around non-functionality. We were allowed to put a camera on as decoration and record what went on in the robot (we actually stored to onboard memory for retrieval after the match), but every single judge wanted to make absolutely sure we weren't using it for real-time driving, because then it wouldn't be a decoration anymore (this was before video was allowed back at the driver station - that has since changed, but their definition of decoration has not). Since that is what you'd be doing with the wireless system, it couldn't be logically defined as a decoration, and so wouldn't fall under the jurisdiction of [R67], meaning [R55] all the way. Sorry - no wireless USB for you.
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 09-01-2012, 08:52
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Originally Posted by Sparks333 View Post
(we actually stored to onboard memory for retrieval after the match).
How were you using this video? For strategy/analyzing how your robot was working/anything like that? Or for a marketing/PR standpoint? If it's the former, it is still not a non-functional decoration because it gives you an edge over the other teams.
[R05] Any non-functional decorations included on the Robot must not affect the outcome of the match and must be in the spirit of Gracious Professionalism.
Also for the OP:
4.1 ROBOT RULES
...When reading these rules, please use technical common sense (engineering thinking) rather than “lawyering” the interpretation and splitting hairs over the precise wording in an attempt to find loopholes. Try to understand the reasoning behind a rule.
Unread 09-01-2012, 13:04
Sparks333's Avatar
Robotics Engineer
AKA: Dane B.
It was most definitely for PR use. It was mounted in such a way that you could not see much of the robot, and, the manipulator rarely entered frame.
Sparks
Unread 11-01-2012, 01:43
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
If you're using the original cRio, what could be done is take a USB-to-Serial chip and hook the USB up to the RS-232 port and start a serial connection.
Attending: MN Duluth Regional
Unread 11-01-2012, 07:47
Those plug into a computer's USB connection and provide a serial port. You want something that goes in the other direction. I don't think you'll find one that's any simpler than something like a USB-host-equipped Arduino or similar embedded microcontroller.
