Thread Tools |
Rating:
Display Modes |
Re: Poly Cord
http://www.durabelt.com/roundoringinfo.php
This is the company that makes the stuff. Look for distributors in your area or on-line. HTH |
Re: Poly Cord
We ordered ours from McMaster. It worked well. There are some guidelines on measurements and what to order and if you follow that it worked very well. (There is a recommended stretch).
Re: Poly Cord
Do you guys order specific lengths or do you order extra and cut to length? If you do the latter then do you use those quick connect fittings or do you weld them together?
Re: Poly Cord
the extra was used to whip the engineer in charge of designing the robot because of how much "fun" it was to put on the robot. |
Re: Poly Cord
Re: Poly Cord
We used the solid polycord from McMaster in 2009. We created a jig and purposed an old soldering iron as the heating element to fuse the ends together, as was previously stated the stretch factor is important.
#8
Re: Poly Cord
We used a piece of steel angle as a jig, clamping the two ends together. We used a creme brulee torch (a small butane torch) to heat the pieces together. As was pointed out earlier, they then need time to cool completely before they are used. Also, be really careful when you sand or cut off any bubbles or bumps. I recommend practicing on a few short bits. One of our mentors and one student became very adept at the welding, so we had one of them do it whenever we replaced the cord.
Side note: If you use polycord that needs welding, you are going to want to have a bunch of replacement lengths already welded when you go to competition. (In general no open flames allowed in the pit area.) |
#9
Re: Poly Cord
We used hollow with connectors for Lunacy and never had a single failure.
#10
Re: Poly Cord
Same here
#11
Re: Poly Cord
Oh...it's called "Urethane Round Belting", not poly cord.
#12
Re: Poly Cord
The recommended stretch 10% is pretty overkill in my experience with the 3/8 solid. If you have more than three or four belts it takes a huge lever arm to get things to line up, and you take a huge performance hit from the all the friction in your bearings. We found 5% much easier to work with, and we even did 3% with no difficulties. (Though as a precaution we shipped the robot with the 3% belts removed so they didn't stretch over time)
#13
Re: Poly Cord
My team used solid core round belting belting material in Aim High and it worked very well for us, but it was a BEAR to melt together. In Lunacy we switched to the hollow core tube belting and used the metal barbs that came with it, and that worked just as good, no failures.
There's a big discussion about the use of polyurethane round belting here if you're interested. |
#14
Re: Poly Cord
Did you use a drive pulley manufactured for poly cord belts, or make one? It looks like some of the drive belts are made out of a piece of pvc pipe with spacers or something similar. It looks like it could get pricy quick to buy multiple drive pulleys.
#15
Re: Poly Cord
What OD's did you guys use in the hollow and solid applications? I would think somewhere around 1/4" would be sufficient but then again I've never used them before.
