Go to Post We can help FIRST improve the system, but we can't just blame them and wait. - Siri [more]
Unread 09-01-2012, 07:16
UriF UriF is offline
FRC #2213
UriF is an unknown quantity at this point
cRIO updating to v43 Image issue
Hey everyone.
I'm just getting ready for the 2012 season and tried to update my cRIO's (old cRio) Image to v43, as Wind River requires it.
Unfortunately, when i attempt at updating it using the Imaging Tool, i get the following error:
Unable to complete operation because of unexpected error 7:
File/Directory Info in ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib:Dialog.vi<APPEND>
C:\Documents and Settings\Owner\Local Settings\Temp\lvtemporary_515166\CRIO
Updating to an older Image seems to be fine.
In addition, I've tried using the NEW 2012 Imaging Tool, and it doesn't even recognize my cRIO.
Has anyone here encountered this problem? how can i resolve it?
Thanks in advance.
Unread 09-01-2012, 07:39
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: cRIO updating to v43 Image issue
Due to major changes in the image format to handle multiple types of cRio's, you MUST use the 2012 imaging tool for the 2012 image.
As to it not recognizing the cRio, can you post more information?
Kettering Motorsports
Unread 09-01-2012, 07:44
FRC #2213
Thank you for your reply.
I believe my cRIO's IP is configured to be 10.22.13.(2?) and my PC is
configured to 10.22.13.6.
As i've said, the old Imaging Tool DOES recognize it. and it can successfully flash older Images.
Please tell me if you need any info that i have not mentioned.
Unread 09-01-2012, 08:05
FRC #2213
Nevermind! I've managed to get the new Imaging Tool to recognize my cRIO. I've done this by restarting my PC and the cRIO itself.
However, when flashing the new v43 Image using the new Imaging Tool I've ran into the following error:
Unable to complete operation because of unexpected error:
Error 15 occurred at Call Library Function Node in nisyscfg.lvlib:Format.vi:1->ConfigUtility.lvlib:2012_FormatSystem.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib:Dialog.vi
Possible reason(s):
LabVIEW:  Resource not found.
Could this have to do with the fact that i haven't installed the things from the NI USB? If so, where could i get the appropriate files? since i don't have the USB currently with me.
Unread 09-01-2012, 08:10
apalrd's Avatar
More Torque!
VRC #3333
Do you have any other ethernet adapters enabled? We saw weird issues in the beta test (although only with the new cRio) if any other ethernet adapters were even enabled (let alone connected).
What image version does the imaging tool show? V43? What version is the imaging tool?
I honestly don't know how the imaging tool will handle several versions of the imaging tool at the same time. We were told to uninstall everything old and re-install everything again, I would recommend that next.
Unread 09-01-2012, 08:26
FRC #2213
[+] I have disabled all other adapters as i have had problems with it before.
[+] the Imaging tool attempts to flash the v43 image.
[+] the cRIO currently has the v20 image.
And if i want to uninstall the old Imaging Tool to try and solve this, how would i go about that?
Unread 09-01-2012, 09:06
Yes.
The 2012 Imaging tool will require the FRC Tools install from the NI USB to function properly.
Unread 09-01-2012, 09:21
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Myself, Everytime I try to open anything from the labview utilities tab on the FRC 2012 update nothing will open. The only thing that will open is the programmer for the boards. Axis setup wont open, cRio imager wont open. Etc.
Anyone else having this issue?
Unread 09-01-2012, 09:25
Have you installed the Utilities Update?
http://joule.ni.com/nidu/cds/view/p/id/2262
Unread 09-01-2012, 09:33
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
On a related note, I saw the behaviour described by the OP when trying to use the 2012 reimaging tool under Windows XP Pro (did not recognize the cRIO, but the older update tool did). I did not encounter any documentation for this application that stated what OS was required, so I wasn't really suprised that it didn't work under XP. Using a different laptop with a Windows 7 OS the same 2012 reimaging tool was able to recognize the cRIO.
It's entirely possible that there was something else going on (non-obvious adapter differences between the two laptops, etc.). Has anyone been able to get it to work under Windows XP? Or found any documentation stating that it shouldn't/won't?
Unread 09-01-2012, 09:38
FRC #2213
I myself got it to work under Win XP. i described above what i have done.
Unread 09-01-2012, 21:38
TimSchley's Avatar
TimSchley TimSchley is offline
AKA: Tim Schley
FRC #0997 (Spartan Robotics)
TimSchley is an unknown quantity at this point
I have also been having some issue re-imaging the cRIO to v43. I am using the old cRIO and a Windows 7 OS. My NI LabView is installed along with the newest java, which we are programming in. We are using a non-classmate driver station to try to update. The IPv4 is configured like this:
IP address: 10.9.97.6
Subnet Mask 255.255.255.0
Default Gateway 10.9.97.6
I have the computer plugged into the first link port on the cRIO. The power is on. Everything electrical is setup correctly. When trying to run the 2012 Re-Imaging Tool, I get the error message that says "No CompactRIO devices were found. Verify the network connection"
Any help would be most appreciated!
Unread 10-01-2012, 00:24
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
I had some issues updating today, and the issue was having more than one network adapter enabled. Even though I was not connected to any wireless network, I consistantly got a timeout error while formatting. Turning off the wifi card fixed this. I hope this helps someone out there
Unread 10-01-2012, 00:57
FRC #2213
If this has any value, I solved my problem by installing FRC Tools from the NI USB..
Unread 10-01-2012, 02:43
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
This is caused by having not installed the utilities update. Sounds like you only have the driver station update.
