Nothing in the KOP can prepare me for you.
Unread 09-01-2012, 09:15
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Single or Dual Speed Transmissions
Single or Dual Speed Transmissions ?
Does anyone have thoughts or insights regarding using a 2 speed super shifter for this years game.
Ed Barker
Unread 09-01-2012, 10:09
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Single or Dual Speed Transmissions
Shifting to a lower gear ratio would probably help during the balancing and the higher one to zip around the field while shooting. Probably not a s simple as that, but that is the only use I see this year and will stay away from it.
Unread 09-01-2012, 11:03
Samk Samk is offline
Lead Builder
FRC #0619
Samk will become famous soon enough
I know the main reason for me suggesting them to my team is for the benefit of the slow speed on the bridge, it could be a real help in balancing
Unread 09-01-2012, 11:17
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
The low gear ratio might help if you decide to cross the bump. Since hitting the bump at speed and using the momentum to carry you over might be rather disastrous for your wheels/frame, low gear could give you the torque to crawl over.
Attending: MN Duluth Regional
Unread 09-01-2012, 14:39
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
I see dual speed being an advantage this year. In 07 bots with ramps were almost useless with single speed partners. With the bridges and very little room to move(with multiple bots) a very slow low gear will probably be a huge advantage.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 09-01-2012, 14:43
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
I think it might be a great year for the supershifter... since 10W 1" stroke solenoids are allowed, I was surprised AM hasn't made a solenoid shift kit...
Unread 09-01-2012, 16:52
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
In 2001, teams 60 and 254 had 2 major advantages with regards to the bridge vs everyone else, generally speaking at SVR that year.
6 wheel drive for stability and a multispeed transmission to quickly balance, using low gear.
It was clearly an advantage, since 2001 was a timed game to win.
I think using one this season has its merits.
Unread 09-01-2012, 17:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
This year seems like a great one for Shifters.
And with AndyMark it is quite easy to get them.
We are defininty heavily considering them, the only issue is being the high price.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 09-01-2012, 17:34
Marc S.'s Avatar
AKA: Adversity
This is an awsome match from '01. Watch for 60 going over the barrier and 254 balancing(they were both 4WD).
Another good match.
This was the alliances best match.
I notice that the bridge that year stayed down while this years bridges stay balanced. That tells me that it will be harder to get on the bridge but easier to balance once on.
Unread 09-01-2012, 17:44
waialua359's Avatar
AKA: Glenn
I must be getting old.
I was there and we were with them.
*mixing up recall of memory*
Unread 09-01-2012, 17:55
teh_lol's Avatar
teh_lol teh_lol is offline
FRC #0486 (Panther Robotics)
Team Role: Driver
teh_lol is an unknown quantity at this point
The way I see it, there will be people trying to knock you around no matter what game it is. You might even be blocked trying to get into the key. A low gear transmission can let you push through any blockers especially when you have high traction wheels. ALso it is good for balancing when you can push your teammates to the right balance.
Unread 09-01-2012, 20:03
PayneTrain's Avatar
PayneTrain PayneTrain is offline
stole 2451's swerve
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
The SuperShifters cost an arm and a leg compared to CIMples or ToughBoxes, but I feel low gear is going to be big this year. I know we will be using them, unless something else happens.
Unread 09-01-2012, 20:11
Andrew Lawrence
Posts: n/a
We were thinking of a "pseudo 2 speed gearbox". By that, I mean we'll be using a single speed CIMple box geared for high speed, but add a button to drastically decrease our speed. We don't think we'll need a lot of torque primarily from the gearbox itself, and we doubt we'll get into any (major) pushing matches, so we think the wheels we're using and the "low speed" button we have will solve those problems.
Unread 09-01-2012, 20:32
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Yahtzee. If slower speed is what you desire, rather than a higher torque, that can be accomplished simply and cheaply via software.
Unread 09-01-2012, 20:34
Andrew Lawrence
Posts: n/a
That's what we're doing. Just press and hold a button and the speed is run at a fraction of the high speed. We used it last year for precision movements, and to make wide turns easier. Loved it then, so we agreed to use it now.
