Go to Post sign up to be an organ donor, and encourage your friends to be organ donors. - dtengineering [more]
Unread 09-01-2012, 03:42
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
Poly Cord
Where is the best place to get the poly cord that a lot of people used in 2006?
Also:
How well did it work in roller system for picking up the balls in the 2006 game? I was not around for that game to much.
Unread 09-01-2012, 03:58
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Poly Cord
Look up urethane belt on mcmaster.
Unread 09-01-2012, 08:44
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Poly Cord
http://www.durabelt.com/roundoringinfo.php
This is the company that makes the stuff. Look for distributors in your area or on-line.
HTH
Unread 09-01-2012, 09:04
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Poly Cord
From McMaster-Carr: link
This is what we used in Lunacy.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 09-01-2012, 10:30
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Poly Cord
We ordered ours from McMaster. It worked well. There are some guidelines on measurements and what to order and if you follow that it worked very well. (There is a recommended stretch).
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 09-01-2012, 10:41
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Re: Poly Cord
Do you guys order specific lengths or do you order extra and cut to length? If you do the latter then do you use those quick connect fittings or do you weld them together?
Unread 09-01-2012, 11:03
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
Re: Poly Cord
we used it in 2009 and ordered extra to cut to length (built 4 duplicate robots that year that were all a little off from each other). to hold them together we welded them with a lighter and then used a sander to shave off the excess bumps that formed from pressing the two ends together. if you go with welding the ends let the cord sit for a couple hours after heating to let it fully set.
the extra was used to whip the engineer in charge of designing the robot because of how much "fun" it was to put on the robot.
Bacon
Unread 09-01-2012, 11:08
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Poly Cord
We have used the same technique on all our robots using round or flat polycord. (04, 06, 08, 09, 11)
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 09-01-2012, 11:15
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Poly Cord
We used the solid polycord from McMaster in 2009. We created a jig and purposed an old soldering iron as the heating element to fuse the ends together, as was previously stated the stretch factor is important.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 09-01-2012, 12:25
mathking's Avatar
AKA: Greg King
Re: Poly Cord
We used a piece of steel angle as a jig, clamping the two ends together. We used a creme brulee torch (a small butane torch) to heat the pieces together. As was pointed out earlier, they then need time to cool completely before they are used. Also, be really careful when you sand or cut off any bubbles or bumps. I recommend practicing on a few short bits. One of our mentors and one student became very adept at the welding, so we had one of them do it whenever we replaced the cord.
Side note: If you use polycord that needs welding, you are going to want to have a bunch of replacement lengths already welded when you go to competition. (In general no open flames allowed in the pit area.)
Unread 09-01-2012, 12:34
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Poly Cord
We used hollow with connectors for Lunacy and never had a single failure.
Unread 09-01-2012, 12:59
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Re: Poly Cord
Same here
Unread 09-01-2012, 13:12
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Poly Cord
Oh...it's called "Urethane Round Belting", not poly cord.
Unread 09-01-2012, 13:18
Best Available Data
FRC #1778 (Chill Out!)
Re: Poly Cord
The recommended stretch 10% is pretty overkill in my experience with the 3/8 solid. If you have more than three or four belts it takes a huge lever arm to get things to line up, and you take a huge performance hit from the all the friction in your bearings. We found 5% much easier to work with, and we even did 3% with no difficulties. (Though as a precaution we shipped the robot with the 3% belts removed so they didn't stretch over time)
Unread 09-01-2012, 14:08
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Poly Cord
My team used solid core round belting belting material in Aim High and it worked very well for us, but it was a BEAR to melt together. In Lunacy we switched to the hollow core tube belting and used the metal barbs that came with it, and that worked just as good, no failures.
There's a big discussion about the use of polyurethane round belting here if you're interested.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
