Go to Post Sadly this bot uses better punctuation and capitalization than many on this site. - Andrew Schreiber [more]
Unread 09-01-2012, 12:42
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
2012 Field Model for SolidWorks?
I know FRC has partnered with PTC and Autodesk, but does anyone have a STP for SolidWorks assembly of the field?
Thanks.
Unread 09-01-2012, 13:17
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: 2012 Field Model for SolidWorks?
I'm also looking for it.
For now, I mocked up the hoops and fender really quick to have something to use to height and distances. They are no where near complete.
Rename the file extension to .SLDPRT instead of .ipt
CD apparently doesn't support Solidworks files.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 09-01-2012, 13:51
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
There is a ProE Version on the PTC Website. I haven't found an easy way of converting an entire assembly and all of its subcomponents to a Solidworks Assembly. If somebody with ProE could open it, and just save as a .Step file, that would be a huge benifit to those teams who work in other CAD enviroments.
The autodesk website doesn't seem to have the 2012 field posted yet either.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 09-01-2012, 14:01
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I use solidworks and download the PTC version. Open the part from solidworks. (if it doesn't show up in the folder you downloaded it too, change the bottom right drop down menu to "all files") It will take a few minutes to open and show the field. but then just "Save" and it converts it to a Solid works part. the field file name is "field_assembly_top_level". Worked for me, hopefully works for you . To prevent everything from moving Mate it as a Lock, by highlighting the whole field, and mate as "Lock". if you want the bridges to move it will take a little longer to do that.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 09-01-2012, 14:13
I get an error:
Empty assembly - No components or components conversion failed.
Could you put your converted version online somewhere for us?
155, teacher: 2011-
Unread 09-01-2012, 14:18
Robotics Engineer
I tried to open a part but SW does nothing. I tell it to analyze completely, or to import it directly, click "OK" and then nothing happens.
Unread 09-01-2012, 14:53
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
The FRC 2012 Kit of Parts and the Competition field are available on the Autodesk Education Community.
Click on this link and check out all the great resources for FRC 2012.
www.autodesk.com/first
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 09-01-2012, 15:06
A STEP file of the FRC 2012 Competition field will be posted on the Autodesk Education Community within 30 minutes.
Phil Dollan
Autodesk Inc.
Unread 09-01-2012, 15:17
Robotics Engineer
Thank you!
Unread 09-01-2012, 15:22
Robotics Engineer
I will upload a .sldasm soon.
Unread 09-01-2012, 15:42
Robotics Engineer
The files is too large for CD, so here's a link.
Unread 09-01-2012, 15:56
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
phild,
Due to school regulations we are stuck with inventor 2011 this year. When I open any files (field, motors, whatever) I get error:
"Error in reading RSe stream"
I assume this is a version difference. Can you please confirm? Is there any capability to get parts capable of use in INV11?
