Thread Tools |
Rating:
Display Modes |
Re: Poly Cord
What OD's did you guys use in the hollow and solid applications? I would think somewhere around 1/4" would be sufficient but then again I've never used them before.
Re: Poly Cord
Yeah 1/4" is what we used. It's the standard cheap yet effective stuff you can get from McMaster and other places
Re: Poly Cord
Are there advantages/disadvantages to using solid as opposed to hollow tubing or vise versa?
Re: Poly Cord
Speaking as someone who was on a team which had little trouble with the solid core, I think the hollow core with connectors is the way to go.
1. Easier to work with at competition (don't need heat source) 2. Less time consuming (no waiting for cooling) We used the solid core largely because we had some, tried and it worked. So we had no reason to try the hollow. I have no idea if one of the two variations is more robust than the other. |
Re: Poly Cord
Thanks everyone for the info concerning the "polycord". I will be placing an order for the 1/4" hollow Urethane Round Belting and barbed connectors.
Two more questions: 1) These round belts in are normally used multiple loops. So, are you machining custom rollers with multiple grooves, or are you stacking off-the-shelf pulleys? Is there a material of choice for the rollers. I suppose aluminum, UHMW polyethylene, or even wood could be used. 2) If we use the barbed connectors, are these actually reliable? Has anyone tried melting the ends in addition to the connectors? Is this overkill? |
Re: Poly Cord
1) You can do either. In the past we have generally stacked pulleys (either COTS from McMaster/SDP-SI or homemade), but a single roller with multiple grooves can be a more elegant solution. I have seen various plastics (UHMW and ABS mostly) turned into roller/pulleys on a lathe, and that works well for many. 2) We have only ever had problems with barbed connections when people got lazy and made poor quality cuts. As long as you make sharp, flush cuts and fully insert the barbs, you will have no issues. |
#7
Re: Poly Cord
we used the custom made ones. There are about 30 on our Lunacy robot (4 different lengths). we still use the robot for demos. none have broken.
I think we used either the 1/4 or 5/16th diameter. |
#8
Re: Poly Cord
We're seriously considering using the round belting for a mechanism this year. One of the ideas I have in mind I either saw or heard about in the past, is to use something like 1.5" nominal ABS sewer pipe, and put short sections of 2" pipe, split lengthwise to make it just a little smaller, over the 1.5" pipe, leaving a short gap wherever a bolt goes. The outer pipe sections could be screwed to the inner one. The inner pipe would be supported at the ends by caps with bearing holes bored in the center, and a sprocket would be screwed to one end of the pipe.
#9
Re: Poly Cord
Our lunacy bot used in house constructed PVC rollers (schedule 80) where the endcaps were drilled out to accept bearings and then it was glued together. To act as guides we sliced sections of PVC that had an inner diameter the same size as the outer diameter of the roller and glued them in place.
Last years roller claw used COTS aluminum rollers that someone found on McMaster. Do be mindful of the span of your plastic rollers if you use them and how much tension they are under. |
#10
Re: Poly Cord
Picture |
#11
Re: Poly Cord
That's a neat idea! You could use just about any kind of tubing with that design, as long as you can figure out how to drive it. Would another section of poly cord work as the drive system from the motor?
#12
Re: Poly Cord
Our team was considering using surgical tubing instead of polycord to pick up balls. Would this work?
#13
Re: Poly Cord
We are going to try out some solid 1/4" Polycord this year. It looks like great stuff. I just hope that it lives up to its acclaim. |
#14
Re: Poly Cord
![]() Last edited by Ian Curtis : 11-01-2012 at 15:29. |
#15
Re: Poly Cord
http://www.chiefdelphi.com/media/photos/33017 |
