Thread Tools |
Rating:
Display Modes |
Re: paper: FRC cRIO II
Is the DB37 cable correct? Some in the kit were built incorrectly. See http://www.usfirst.org/sites/default...structions.pdf |
Did anybody ever find out if you could use the fourth slot as an additional digital sidecar module?
You can use it for any of the 3 modules. The module you insert will be detected at power-up.
I can not access the digital soft switches for the cRIO in the new imager, does anyone have any suggestions? I am using the new cRIO II
I am using the crossover cable, the imager gave a new name to he cRIO II and the IP address alright, but I can not upload an image. |
What happens when you try?
#7
Unable to complete operation because of unexpected error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1 Possible reason(s): NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline. Complete call chain: nisyscfg.lvlib:Restart.vi:1 ConfigUtility.lvlib:2012_FormatSystem.vi ConfigUtility.lvlib:ReImageTarget.vi ConfigUtility.lvlib ialog.vi |
#9
The cRIO II has the IP address and name, but when I select the option to image it, it does not allow me to. It gets halfway through the formatting process, and it displays the above ^ error code.
#10
Make sure your computer's netmask is set to 255.255.255.0 and that you have disabled (by right clicking and selecting "Disable") any adapters other than the one being used to connect to the cRIO.
#11
I have done that, and it still does that.
#12
I've seen that error go away when all other NICs get Disabled.
#13
You might also have a Windows firewall enabled. Shut anything like that off. |
#14
