Go to Post We try to limit ourselves only by physics. As the first person on the planet to communicate over a quantum encrypted AOL instant messenger session, I try to ignore those limits as well. - EricVanWyk [more]
Unread 09-01-2012, 01:47
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Shooting from opposite side of the field
CIMs have a torque of 45 ounce-inches (0.234375 foot-pounds) at peak efficiency according to the manufacturer. The simplest solution is to just put a wheel on the end of a CIM to increase torque and increase linear momentum conveyed to the ball.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 09-01-2012, 04:12
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
The fun thing about gearing though - it does come with a built-in cost. You can most certainly get a ball to go virtually any speed with a properly-geared CIM and wheel (within reason), but the higher the speed, the longer it will take the for motor to get the shooting wheel back up to launch speeds - don't expect to fire of a quick volley from that range with only one motor/wheel combo - expect a slower firing rate due to the energy required to fire the ball at that speed and the power available via the motor.
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 09-01-2012, 06:53
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by Justin Montois View Post
By "do it" do you mean just shooting from the far side of the field or actually scoring...
I think you will see some teams consistently (or nearly consistently) score from just past half-court.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-01-2012, 07:30
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
If you can hit 1 of 5 or 1 of 6 from the far side of the court you are accomplishing 3 things.
  1. you are scoring
  2. You are feeding your team balls and elliminating the need for them to make a trip
  3. You are defending by moving balls out of the opponents side
You still need to be accurate and we believe that you will also need to be 1 out 3 or 1 out of two in your zone to be truly an effective team mate.
Here is some info on targeting we have whipped up http://www.atomicrobotics.com/2012/0...ot-larry-bird/
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 09-01-2012, 12:06
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Originally Posted by Gray Adams View Post
I haven't really done any math, but putting a wheel directly on a CIM spins terrifyingly fast, and has a sound to match.
but we are limited to 4 CIMs this year, and about 99% of teams are going to use them for drive.
http://www.andymark.com/product-p/am-0932.htm
http://banebots.com/p/S24K-C1-7
So the question becomes, FP or banebots.
And also, if banebots, one gearbox or two hooked up to a single wheel shooter? (Limit 2 FP, 4 Banebots [R65], and correct me if I am wrong but each box takes two motors)
Unread 09-01-2012, 12:08
Chris is me's Avatar
AKA: Pinecone
Yet it worked in 2006 and 2009!
Unread 09-01-2012, 13:29
martin417's Avatar
martin417 martin417 is online now
Opinionated old goat
AKA: Martin Wilson
Everyone seems to be focused on whether or not a team can achieve the distance on a given shot. I believe that will be fairly easy to do. The real problem with distance is accuracy. remember that no design can be 100% consistent, and higher velocity could increase the error. The error in the landing point is given by:
err=tan(angle error) X distance
(assume two dimensional, looking down on the bot, the problem is compounded in three dimensions)
If the angle error is small, the tangent of that angle is small also, but if the distance is large, even that small error can make a big difference in landing point.
Example:assume you launch and have a 1° error in your launch direction. If you are 10 feet from the goal, you will have an error of ~2.1 inches. Assuming your aim was perfect, the ball will land ~2.1" from the center of the hoop and score.
Now move to 50 feet away (for round numbers) and keep the error the same. Your positional error is now 10.5 inches. if your aim was perfect. you will hit the rim and very likely not score. The center of the ball will be 1" outside the rim.
If you now add vertical angle error into the equation, it becomes much worse because your distance has the same relationship. Hitting a long field shot will probably happen, As I have seen full court shots hit in basketball, but I doubt many games will be won due to super long shots.
Former Mentor Team 1771
Former mentor Team 4509
Unread 09-01-2012, 14:47
Bob Steele's Avatar
AKA: Bob Steele
I agree with the above comment...
From my experience... when you lose contact with an object... all sorts of things happen to it that you can no longer correct for. The longer it is in the air the more things can happen...
Remember... at these big velocities you can no longer use the simple physics formulas that most of us learned in high school physics... air resistance is NO longer negligible .. and you may approach terminal velocity...
but even if you don't, you will have a constantly changing velocity due to air resistance...
Has anyone determined the terminal velocity of these basketballs?
I am very encouraged to see so many teams putting their effort into scoring from long range... I applaud their efforts... it is great physics/math and great engineering...
Now is it the best thing to win the field game with> ??? not so sure...
I do know that if I am watching an NBA game and a guard is getting ready to shoot from beyond the 3 point line ..that if he spies a team mate wide open with no defensive player on them closer to the basket ... that he will make the pass... and if he doesn't... the coach will pull him out...
That being said... who really is the winner in FIRST?
Doing the math/science to put in a shot from half court... that is also winning.... and maybe in a more important way....
Good luck to all of you
We will see you on the field!!
Unread 09-01-2012, 15:06
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Do remember that after the first week the balls are going to be deformed from use which will affect the accuracy of long shots. Just to get them to the other side of the field will not take as much energy.
Unread 09-01-2012, 15:14
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
We did some imperical testing using our Aim High robot. It appears to be feasible to shoot this year's game piece from about 30 feet with some consistency.
Unread 09-01-2012, 16:25
FRC Regional competitions typically do not reuse game pieces from previous weeks.
Unread 09-01-2012, 17:01
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Based upon our experiences with FP-driven pinch rollers, yeah, I'd say 30-35 feet with consistency is reasonable.
Here's team 95's 2006 Aim High robot, Lilly (whose accuracy is better than it looks, since it had three parallel firing channels):
Unread 09-01-2012, 17:39
Djur's Avatar
WPILib
AKA: Sam Carlberg
How accurate was it at 30' though? Aim High had a 30" goal and Rebound rumble has an 18" hoop, so you'd need to be accurate within a much smaller area.
EDIT: Check out this post. It doesn't say how accurate the shooter was, but a 60' shot is pretty good. (19:14 EST)
Last edited by Djur : 09-01-2012 at 19:14. Reason: New information; didn't want to double post
Unread 09-01-2012, 19:40
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Have you guys considered the fact that only 4 CIMs are allowed this year? Are you willing to sacrifice 2 CIMs to use for a shooter instead of on the drive? Just from past experience, only using one per gear box (6 wheel here, not mech or omni) will trip the amp breaker. We had to gear it lower to actually move and the max FPS we got was about 8-9 FPS. Is that worth it this year? What motors are a good alternate for the shooter? Fisher Price ones?
Unread 09-01-2012, 19:44
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Ryan_Davis is an unknown quantity at this point
That's frightening.
"Quality means doing it right when no one is looking."
-Henry Ford
