Go to Post There are certain questions that one never, ever should ask. - dlavery [more]
  #46   Spotlight this post!
Unread 08-01-2012, 00:47
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Strategies for Rebound Rumble
Originally Posted by donnie99 View Post
It doesn't specifically say you can't touch the hoops, but if you damage them, it will be a penalty under the safety rules, and yes, the most is 84" on the scoring half.
Just as a note - although this already has been raised in various other threads - the dimension constraints also physically limit you from extending the robot sufficiently close enough to the hoops to contact them.
Perhaps aiming at a certain point on the rim to bounce the ball in would work - FIRST must've replaced the springs for a reason.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
  #47   Spotlight this post!
Unread 08-01-2012, 00:51
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
also there is nothing stopping you from going onto the fender as of right now.
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
  #48   Spotlight this post!
Unread 08-01-2012, 09:18
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
What about building a super small robot that is great at climbing the bridges? Their likely won't be 24 teams that can score hoops or shoot balls, so if a top alliance's 3rd robot gives them a huge advantage in getting 3 teams balanced for 40 points, I think they could be valuable.
  #49   Spotlight this post!
Unread 08-01-2012, 09:37
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Originally Posted by Tubatroopa View Post
One thing to remember is what worked in 2001 may not work today due to bumpers.
  #50   Spotlight this post!
Unread 08-01-2012, 17:29
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Originally Posted by Tetraman View Post
It was shot down in our meeting, so here is my idea:
Make a robot with a ramp allowing another robot to drive on top of you, and you then solve the problem of how to get 3 robots on the bridge. Also, you can use it with your opponent's robot so you and your opponent can easily balance on the Coop bridge together as one entity rather than two.
Or... what if you then lifted the other robot up, such that the combined stack of robots was high enough to block the middle, or even the high hoops?
Does anyone else remember when TBA signatures actually worked?
  #51   Spotlight this post!
Unread 08-01-2012, 18:28
FantomDannie's Avatar
FantomDannie FantomDannie is offline
The Hero
AKA: Andrea Robles
FRC #0145 (T Rx)
Team Role: Student
FantomDannie is an unknown quantity at this point
Send a message via AIM to FantomDannie
So, if we were to have defensive robots, we'd be at a slight disadvantage due to height of the hoops versus the 60 in height limit on the robot. That makes sense - we'd just have to find a way to implement the defensive strategy in some other ways. Does anyone else have an idea about the defensive line of the game?
One other thing: Do we have to play the game as full court? As in, crossing over the barrier at least once or all the time. Along with that, is it against the rules to have a robot stay in a corner during the game?
  #52   Spotlight this post!
Unread 08-01-2012, 18:31
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
You may take shots from anywhere on the field, and as long as you are not in the opposing alliances zone, corner camping is perfectly legal.
  #53   Spotlight this post!
Unread 08-01-2012, 19:39
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
But you should know that your supply of balls is dependent on how much your opponent can score.
  #54   Spotlight this post!
Unread 08-01-2012, 19:43
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
or how much they miss...
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #55   Spotlight this post!
Unread 08-01-2012, 19:47
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Or how many you score and then force out of the opposing inbounders.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #56   Spotlight this post!
Unread 08-01-2012, 19:49
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Maybe a better defensive strategy is rebounding missed shots and passing those and inbound balls to offensive teammates?
Perhaps the nature of defense for this game is not to prevent opponents from shooting but forcing them to shoot from positions with a higher chance of missing?
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
  #57   Spotlight this post!
Unread 08-01-2012, 19:55
Ninja_Bait's Avatar
AKA: Jake Potter
Defense for this game will just be preventing scoring by any (legal) means possible. That means forcing bad positions, starving balls and blocking shots.
  #58   Spotlight this post!
Unread 09-01-2012, 11:57
RedLeader342's Avatar
RedLeader342 RedLeader342 is offline
Fabrication/Drive Coach
AKA: Justin White
FRC #0342 (Burning Magnetos)
RedLeader342 is a jewel in the roughRedLeader342 is a jewel in the roughRedLeader342 is a jewel in the rough
Originally Posted by Silver218 View Post
For any defensive bots, what would be your teams strategy? We have talked about a defensive bot to possibly block shots from opposing teams
unless the robot is in the foul zone, or the key, you can put up a little arm thing and block shots from right up in their face and be all like TROLOLOLOLOLOLOLOL
2009-Mechanical and Scouting student,342
2010~12-Mechanical, Fabrication, Operator,342
2012~13- Fabrication Mentor,3196
2013~Present- Fabrication/Drive Coach, 342
  #59   Spotlight this post!
Unread 09-01-2012, 16:21
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
A burst of air can divert a shot at a distance.
  #60   Spotlight this post!
Unread 09-01-2012, 16:26
wilhitern1's Avatar
AKA: Neal Wilhite
If a robot's wheels are parallel to its short side rather than its long side, it takes up a lot less space.
If a robot was heavily balasted to one end, it would balance much easier, even hanging off one end.
