Go to Post The GDC made something easier??? Link or it didn't happen! - JesseK [more]
Unread 07-01-2012, 14:57
Yppiz's Avatar
Yppiz Yppiz is offline
FRC #1014 (Bad Robots)
Rookie Year: 1776
Yppiz is an unknown quantity at this point
Exclamation 2gopc 2012 Image
How do you load the driver's station software onto the 2012 2gopcs? When we load the image from the flash drive, it runs with an error saying that the user does not have administrative privileges (it does). Any help? We need it soon.
My friend VICTOR has a JAGUAR and a 2CAN, and from his Lab'sVIEW he can CRIO grande. Do the puns have you VEXed? You're not the FIRST.
Unread 07-01-2012, 15:00
Yppiz's Avatar
Rookie Year: 1776
Re: 2gopc 2012 Image
Update: After a reboot, it still fails to load, but without the admin privileges warning
Unread 07-01-2012, 15:39
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Our image didnt come with the driver station software on it. Try using this:
http://joule.ni.com/nidu/cds/view/p/id/2263/lang/en
Password is
!HotShots!KnowBalance!
Unread 07-01-2012, 15:44
Yppiz's Avatar
Rookie Year: 1776
Solution found: Press f11 when the computer boots to boot from the flash drive, go from there.
Unread 07-01-2012, 16:32
Yppiz's Avatar
Rookie Year: 1776
Where did you find that by the way?
Unread 09-01-2012, 16:38
Team2246's Avatar
Team2246 Team2246 is offline
AKA: Jon Mardyla
FRC #2246 (The Army Of Sum)
Team2246 is an unknown quantity at this point
Okay hope someone can help me. I only quoted the above statement to make it clear that i do understand that. But everytime i try to do that it says: "a disk read error occurred press Ctrl+Alt+Del to restart"
So just curious can i just update all the driver station software? Cause i don't see a use to reimage the netbook if the driver station software is updated.
Thank you
Unread 10-01-2012, 01:22
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Thank you
I ran into 4 out of 15 E09 classmates at kick-off that reported this error with all of the thumb drives we tested (ones that worked fine on other E09s there).
We dealt with it by simply uninstalling the old NI software and open office (to make space) and installing the Driver Station support files and then the Driver Station update. Then you can include the Kinect SDK and Kinect server if you wish.
Unread 14-01-2012, 12:25
ssmith2 ssmith2 is offline
FRC #1737
ssmith2 is on a distinguished road
We currently have this same error. Is the above the "official" resolution? I am assuming not but don't know.
Unread 14-01-2012, 12:28
FIRST posted a procedure to fix your drive. Make sure you back up the files on it first:
http://www.usfirst.org/sites/default...ation_Rev0.pdf
