Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 09-01-2012, 17:20
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
General Questions?
So after completely reading the rules, our team has yet some more questions!
Can the ball be dropped into the robot from the imbound station directly? i.e. the inbounder has too many balls and must immediately put them through he slot. So he drops it in and our robot just happens to be directly under it.
Is the robot on when put in the field? (were rookies and were not sure based on how BEST works)
What is concidered "in the key" when being protected or whatever?
Unread 09-01-2012, 17:23
Happy Birthday! EricH EricH is offline
Re: General Questions?
1) I see no rule prohibiting this. As such, it is probably allowed (but CD is not an official source of information). Ask the Q&A when it comes up to be sure.
2) Off, then turned on once it's on the ground in starting position. It will be in the disabled state, however.
3) In contact with the key. See [G28].
Unread 09-01-2012, 17:27
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
This is somewhat situation specific because some events for the sake of time ask you to turn on your robots in queue but for the most part it should be fine if you turn it on when you set it on the field.
One does not have to be totally in the key to gain its protection. As long as a robot is contacting the key than it can't be touched by an opponent robot. (G28).
461 Westside Boiler Invasion
45 Technokats
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
The Key is the solid color half circle. As long as you are touching that solid color Key area (not hovering over it - actually touching it), you are 'protected'.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 09-01-2012, 17:37
Eric222 Eric222 is offline
FRC #0222 (Tigertrons)
Team Role: Student
Eric222 is an unknown quantity at this point
yes but your opponent is the one with the balls and may try to not drop it in your bot but rather throw it through the imbound station.
I think you have this confused...the human players on your alliance will be your inbounders, (the ones who could give you the balls).
http://tigertrons.net/
Unread 09-01-2012, 17:55
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
This is incorrect.
From the perspective of a driver on the red team:
-Your inbounder is standing very close to you
-The red goals are on the far side of the field from you
-Your (red) alliance lane is to your right, and as such, the (red) inbounders on your team will be putting balls into the field from there.
http://www.google.com/imgres?um=1&hl...0&tx=120&ty=49
Unread 09-01-2012, 18:05
45 Alumni
AKA: Peyton Yeung
I see my mistake and thanks
45 Technokats
Unread 09-01-2012, 18:18
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
It is legal, but executing it may be difficult depending on your design. Remember that the Inbounders must remain behind the Starting Line (which involves throwing the balls through the slot), so the balls can, at best, be aimed in the general area of your robot's collection system.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
