Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 08-01-2012, 13:52
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Questions on the arena
Originally Posted by Bjenks548 View Post
Everyone could just pass one ball to the right. The in-bounder on the far right puts one of his/her balls into play. I'm very curious as to what the "Immediately" means exactly. Is it up to the refs? Is there a set time? Either way, hording 6 balls could be a dangerous strategy...
I would assume eventually an update will be released giving an exact formula/algorithm of some sorts to determine this-I believe that's what they did in 2010. Basically, IIRC, the way formula/algorithm was written was so that you had more time to get rid of the balls once you had more balls in the alliance station.
Unread 08-01-2012, 14:16
minibot263 minibot263 is offline
FRC #0263
minibot263 is an unknown quantity at this point
Im wondering if you get penilized for entering the other alliances alley? I havent seen any rules about not being allowed to.
Unread 08-01-2012, 14:17
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
You are only penalized when you touch an opposing robot in the alley. Same for the keys.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 14:24
AKA: Scooby
No, there appears to be no penalty for entering your opponent's Alley(and you don't get penalized in the Catalyst simulator), only when there is contact. Regardless of who commits the contact. In other words, if you're in your opponent's alley, you're fine, but if someone on your opponent's alliance touches your robot, the penalty is against you, per <G28> and the blue box underneath it:
[G28]
Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge.
Violation: Foul; Technical-Foul for purposeful, consequential contact.
This rule applied at all times, no matter who initiates the contact, see [G44].
bhaidet's Avatar
bhaidet bhaidet is offline
FRC #0435
bhaidet is an unknown quantity at this point
Originally Posted by Steve Howland View Post
Looks like you could possibly bounce them through the slot to the other side, as long as nothing is in the way.
This would change our strategy massively. Does anyone have a setup to try it yet?
Unread 08-01-2012, 14:31
AKA: Scooby
It's not necessarilly a setup needed in my opinion, moreso just the brute force required to do such a thing. And the fact that rule <G33> doesn't clarify whether or not Inbounders can break the vertical plane formed by the Starting Line, or if the rule is only that their feet can't cross it, so that's something to think about. Also keep in mind, the under-publicized "end game", as I consider it, is that in the last 30 seconds, you can throw the ball over the Inbound Station.
Unread 08-01-2012, 17:41
Snorlax Snorlax is offline
FRC #3229
Snorlax is an unknown quantity at this point
We had a field set up in NC yesterday and one of the mentors demonstrated a method of throwing the ball through the slots so that it would bounce over the barrier if unimpeded.
Unread 08-01-2012, 17:47
GaryVoshol's Avatar
Cogito ergo arbitro
Past interpretations have been foot faults. In fact, it pretty much has to be that, because the Corral is beyond the Starting Line. You can't have one rule that says the Inbounders must reach across the line, and another that says they can't. But it's something to ask the GDC.
(since 2004)
Unread 08-01-2012, 17:56
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Except...
[G33]
Inbounders must remain behind the Starting Line during the Match.
I'm not sure the Starting Line extends across the front of the Corral, so the question may be irrelevant anyway.
Does anyone else remember when TBA signatures actually worked?
Unread 08-01-2012, 19:40
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
Keep in mind that in 2010, there were sensors that could keep track of every time a ball entered and exited. There are no sensors (as far as I can tell) on the inbound slot. Hence it would be kinda hard to determine the time it takes to inbound the ball after it is scored.
Unread 08-01-2012, 20:09
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
That is only if we can have more then one inbounded with a set. Also, we will need to ask if passing is aloud.
Unread 09-01-2012, 00:58
Jimmy K's Avatar
[G31]
Only Inbounders may contact Basketballs; each Inbounder may hold a maximum of two Basketballs. During Teleop, Inbounders must remove Basketballs from the Corral immediately upon arrival. All Basketballs in the Alliance Station must be held by Inbounders once removed from the Corral.
Violation: Foul
If one Inbounder passes (throws) the Basketball to another Inbounder, then after the first Inbounder throws the Basketball, but before the second Inbounder catches it:
The Basketball in the air, it has been removed from the Corral, it is in the Alliance Station, but it is not being held by an Inbounder. This seems like a violation of [G31].
Of course, by this interpretation, throwing the Basketball into the Inbound Slot would also violate [G31] despite probably being within the intent of the game rules.
Unread 09-01-2012, 15:22
FRC #2493
Huh, that is interesting. But, we don't need to 'throw' it either. Can just do a line and pass it if you desire.
Back to the original question, it is sounding like we can have up to three in-bounders holding 6 basketballs at one time?
Unread 09-01-2012, 18:09
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Tried! Succeeded. Was able to get one bounce in the near court and the next in the far court on my best try. With nothing but field elements in the way, I was able to get around 75% over the hump. With practice and more youth, I'd predict more like 95% for the best throwers. A variant of a volley ball serve can be made to work too, but I only tried it once.
Unread 12-01-2012, 10:47
bhaidet's Avatar
FRC #0435
Cool! Thanks!
