| View Poll Results: Are you designing your robot with the idea of being able to fit 3 robots on the ramp? | |||
| Yes, it is going to be a key component to winning in Eliminations |
188 | 73.44% |
| No, it's not worth the trouble and time |
74 | 28.91% |
| Multiple Choice Poll. Voters: 256. You may not vote on this poll | |||
Thread Tools |
Rating:
Display Modes |
Re: Going for 3 robots on Ramp?
Don't all the robots have to be supported by the bridge?
find the rule that says that I can't seem to find it...
Does it break the bumper rules if you extend a leg down to balance the bridge and support yourself if you were on it but hanging off the edge? I'm not clear on that.
You are allowed to extend up to 14 inches beyond the frame perimeter...
That's for outward protrusions. Can you extend downward?
thats a good question for the Q&A
#7
That is true. I was hoping someone had figured it out, but I also forgot that CD is not the GDC. (Otherwise we'd be better at getting the game hints!
#8
The coopertition bridge is a different rule. |
#10
Maybe he didn't understand what I meant or you didn't but i mean to put a robot on another robot and then get on the bridge and have it balance. As for him I think he wants to know if my idea is against the rules but I don't see where it says that you can't. |
#11
We do not have a Ramp yet to test balance but what about getting creative. Three robots could fit easier under an angled configuration...
#12
(emphasis mine) I see the "must be balanced" rule for the alliance bridge (G40), but where's the "must be supported" rule? It's mentioned in G41 w.r.t. the coopertition bridge if that bridge isn't balanced. No where I can find does "balancing" either type of bridge required any robot to be "fully supported" by said bridge. Did I miss a definition or something somewhere?
#13
The intent of G41 is clearly to prevent robots from claiming coopertition points by driving up the bridge halfway but still be half on the carpet. G41 doesn't even prevent another robot from going to the coopertition bridge to aid balancing (obviously, as long as it doesn't break other rules) by supporting the bridge itself. I think aided balancing is a perfectly valid strategy.
#14
Yeah, I dont know what prevents you from taking the 111 approach in 2001...
Seems ok |
#15
Any hints on how to build these ramps? |
