Go to Post The horse is dead; stop beating it please. - DonRotolo [more]
Unread 09-01-2012, 19:25
om23 om23 is offline
AKA: Om Mahida
om23 is a jewel in the roughom23 is a jewel in the roughom23 is a jewel in the rough
pneumatics or motors?
In this year's game you can either. My team's inexperienced with pneumatics and more experienced with using motors. But using pneumatics this year seems more beneficial.
What are the pros and cons of each for this year's game?
For your ball shooting mechanism?
College Student | "It won't fail because of me."
Unread 09-01-2012, 19:26
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Re: pneumatics or motors?
Using pneumatics vs motors in what aspect? We need more detail before we can comment.
2012-2016 Wave Robotics Team 2826
Unread 09-01-2012, 19:29
Andrew Lawrence
Posts: n/a
Agreed. While I wouldn't use pneumatics for certain applications (like driving my drivetrain), I would definitely use them over motors in other applications (such as linear movement).
Unread 09-01-2012, 19:34
Don't be lulled into false hope with the number of available motors. Add too many or have several running at the same time can cause you to draw the battery down to critical levels. Remember that the Crio will automatically disable all outputs when the battery voltage falls to 5.5 volts. It will generally reboot if the battery voltage falls to 4.5 volts for a short time. You are being given more motors to choose from for your particular design. Use them wisely.
Unread 09-01-2012, 19:51
AKA: Om Mahida
ahh sorry guys. My bad. What I mean: pneumatics or motors for shooting?
Unread 09-01-2012, 19:54
Andrew Lawrence
Posts: n/a
Depends on your design. In my opinion, based off of tons of research, pneumatic rams would need reloading, and would have not as much power as motor powered shooters. For shooting basketballs, just use motors.
Unread 09-01-2012, 20:00
BigMac3696 BigMac3696 is offline
FRC #3696
BigMac3696 is an unknown quantity at this point
I didn't see a possible way to use pneumatics to shoot consistently. You have to have a huge amount of force just to get the ball to move. My team tried it with a tennis ball earlier in the year to test the idea of shooting anything using pneumatics, and it barely made it 10 feet. That was with all the air pressure they wanted to use. They didn't have a tank restriction and didn't use just 60 working psi. It was unimpressive. I could be wrong, and there could be a genius way to use them. But right now using a baseball pitching design seems to be the only viable option to keep a consistent shot while it being reasonable in the sense that you can do it more than once.
Unread 09-01-2012, 20:12
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I just don't see any way that you can flow enough air to move a piston fast enough to launch a ball any impressive distance. For close up action that may work fine, but the maximum valve port diameter restrictions in the rule book just seem too restrictive to do anything worth while.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 09-01-2012, 21:46
Don't underestimate what's possible with pneumatics. Watch the robot in the lower right in the following video kick soccer balls pneumatically. http://www.youtube.com/watch?feature...4VhtI#t=16 0s
Unread 09-01-2012, 22:01
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by Joe Ross View Post
Don't underestimate what's possible. Watch the robot in the lower right in the following video kick soccer balls pneumatically. http://www.youtube.com/watch?feature...4VhtI#t=16 0s
That was fully pneumatic? Wow, I always figured it was surgical tubing/etc. Care to elaborate? That was (albeit entirely characteristically) an amazing machine.
Unread 09-01-2012, 22:12
DonRotolo's Avatar
Back to humble
FRC #0832
Using a pneumatic cylinder to push balls directly will be disappointing, given the equipment legal on an FRC robot.
In Breakaway, many teams kicked the soccer ball using latex tubing to power the kicking 'leg, and then used a cylinder to reset the 'leg'. A latch held the 'leg' in place until the driver decided to kick again.
In Aim High, the more successful robots used a spinning wheel, like a baseball pitching machine uses, to launch balls. A well-designed mechanism was extraordinarily repeatable, but that is difficult to actually do, since the wheel wants to slow down as its momentum gets put into the ball.
Don't be afraid of pneumatics, but please read the rules very carefully to make sure your robot uses ALL of the safety equipment properly. This includes the 120 PSI relief valve*, the pressure release valve, the pressure switch**, the primary regulator, both pressure gauges, and the cRio and a Spike to control the compressor.
*This is supplied uncalibrated, be sure to calibrate it before use
** This is wired to a digital input of the digital sidecar. That signal is used by the cRio to control the Spike relay controlling the compressor.
Unread 09-01-2012, 22:13
There are some details in this thread http://www.chiefdelphi.com/media/photos/35118
Unread 09-01-2012, 22:23
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
If you want to see pneumatic shooting at its best, check this out:
http://www.youtube.com/watch?v=cdzpC...&lf=plpp_video
close up CAD rendering of the robot:
http://www.teamtitanium.org/images/09botfull.jpg
I got to see this robot up close when it was in use for Lunacy, it was a really beautiful job!
Unread 09-01-2012, 22:28
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
In Aim High, pretty much any team that did throw balls used a motorized wheel, like the aforementioned pitching wheel. It did have the tendency of slowing down the wheel, but if you give it a second or two to ramp back up to speed, I think it'll still be faster than drawing back a pneumatic cylinder to reload.
If you want to use pneumatics, my suggestion would be to use a "catapult" type arm to throw the ball, and place the pneumatic cylinder between the fulcrum and the load of the arm. Think how a hammer works driving a nail... the fulcrum is the butt of the handle, the arm swinging it is the arm (located up more on the handle), and the load is the head driving the nail with a lot of speed.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 09-01-2012, 22:48
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Neither of you are thinking outside the box
Take a 12" cylindar. lock it 1/2 way (mechanical lock like a fence latch). pressurize the cylindar. release the lock and see how fast the cylindar reacts and how far you shoot the ball.
oh, I'd put a hard stop on the rod so you dont damage the cylindars end cap
___________________
- Tennyson, Ulysses
