Go to Post While there are reasons to keep a float charge on your batteries, it may be like giving your son a flu shot when he has the measles. - ATannahill [more]
Unread 09-01-2012, 22:16
Charmander's Avatar
Charmander Charmander is offline
None #1714
Charmander can only hope to improve
Mecanum Drive Train
Hello!
For all the teams deciding to go Mecanum, how do you plan on overcoming the bumps without damaging the wheels too badly. Also, do you think the wheels will have issues with going over the bridge. (the bridge has a plastic coating on top)
Unread 09-01-2012, 22:19
tetravaal tetravaal is offline
FRC #2461
tetravaal is an unknown quantity at this point
Re: Mecanum Drive Train
We are using 6in mech's and we DONT plan on going over the bump.. Are you sure about the info on the ramps? My guys who went to the kickoff swore they were coated with carpet like the field.
Unread 09-01-2012, 22:20
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
the bridges are HDPE. Read the arena rules and watch the videos on FIRST's you tube channel
2012-2016 Wave Robotics Team 2826
Unread 09-01-2012, 22:21
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
But their top surface is polycarbonate.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 09-01-2012, 22:22
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
We have done Mecanum/Meccanum/Mechanum/Whatever (someone who knows please do tell) for the past two years, and we are not doing it this year. Ignoring speed and being defended reasons, there are year specific reasons for not choosing it.
  • Teams that try to cross the ridge unaided with only mecanums will fail miserably and probably damage the rollers or wheels
  • The meccanums will not drive nicely on the slick material/polycarbonate of the bridge and the key.
For these reason among other prevolent ones, I urge all teams not to use Mecanum, unless you have a very specific design to overcome these obstacles (e.g. jumpdrive)
Hope this helps,
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 09-01-2012, 22:25
Ninja_Bait's Avatar
AKA: Jake Potter
Mecanum.
Unread 09-01-2012, 22:26
polycarb or HDPE doesn't really matter its going to be hard for mecanums to get a grip on them to climb onto them...
Unread 09-01-2012, 22:29
Charmander's Avatar
None #1714
We plan on using Mecanum wheels and we plan on going over the bump. The question is, what should we use to prevent direct impact to the wheels. Right now, we are thinking of a plow or a a raised dummy wheel to take the initial impact of the bump and raise the bot up a bit before the Mecanum wheels hit the bump.
Unread 09-01-2012, 22:33
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
More info here and here
Waittt a second. You already posted this thread. Please do not double up. The forums are bogged down enough already. Normally I'd be a lot more upset, but I'm in a good mood right now.
Unread 09-01-2012, 22:40
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I really don't understand why everyone says mecanum wheel won't get a grip on the ramp. Mecanum wheels have no more problems with grip than any other rubber wheel on polycarb.
On the other hand, hitting the ramp crooked can cause difficulty because of the disruption of the vectors when one wheel hits the ramp causing other wheels to loose contact with the ground. This can be a big problem especially for chassis without much flex.
I think mechanum wheels will have less trouble with the bump than the ramp because of the natural tendency of the flat bump to actually straightening out the robot when hit.
Unread 09-01-2012, 23:31
Charmander's Avatar
None #1714
The other thread was oriented more toward the question of IF mecanum wheels could handle it. This one is oriented toward the question of HOW (design ideas) mecanum wheels could handle it. But there are similarities. I'm glad you're in a good mood however!
Unread 09-01-2012, 23:46
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
We tested our mecanum bot from last year on a simulated ramp using whiteboards as the surface and managed to climb onto the ramp without a problem. The whiteboards should simulate the ramp surface for our purpose I feel.
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 10-01-2012, 01:15
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
We tested last year's bot (mecanum wheels) on our prototype ramp after covering the ramp in regolith. It climbed up fairly easily and was able to balance within ten seconds. We're going to try to buy a sufficiently sized sheet of polycarbonate soon for testing purposes, but I feel pretty good about the chances of mecanum being able to do this.
