Go to Post ADMIT IT! Dave Lavery has better legs than Amanda Morrison! - DCA Fan [more]
Unread 09-01-2012, 22:15
Programs-R-us Programs-R-us is offline
FRC #3313
Programs-R-us is an unknown quantity at this point
Input/Output programming for Labview
I'm trying to find something in labview to read data from a numpad, because we want to use a code to override the automation that were going to be running? What labview function, (If there is one), Would allow us to do that?
Unread 09-01-2012, 23:04
Re: Input/Output programming for Labview
What do you mean by "numpad"? Are you trying to read something connected to the robot? How is it connected?
Unread 10-01-2012, 00:39
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
What is sounds like is that you want to make a case structure in labview. This would be able to switch between multiple groups of code.
If you want to stop all of the automation an your robot there is an extension for the driver station called a stop button. It will stop all automation fast
Unread 10-01-2012, 02:37
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
If the "numpad" you are talking about is part of your driver station laptop keyboard, then you need to make a custom dashboard that reads the keyboard input and sends the data to the robot using UDP or TCP. One of these days there may even be a NetworkTables implementation for LabVIEW that would make this even easier.
Unread 10-01-2012, 09:15
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
You can also use the Driverstation Virtual Digital Inputs. From our testing these are read continually during the Teleop Mode, although I'm pretty sure (at least a few years ago) this wasn't true. In the Default Projec there is already code in the Autonomous.vi for reading this data, you can copy that into your Teleop.vi to use it there.
