Go to Post Battle Bots and other robot fighting competitions is to First Like McDonalds to Hamburgers They get the idea, and have the taste, but they are bad for you in the long run. - Conor Ryan [more]
Unread 09-01-2012, 20:55
eulerddx4
Posts: n/a
Can't Install Windriver
Hello, I have a mac and am using VMware w/ windows 7. I know that Professor Miller uses this configuration so in theory I should have no problem. For some reason when I put in the disk and click setup.exe as it pops up - the disc spins and then I get "An error has occured. See the log file \\ vmware - host\ shared Folders\ .wrinstaller -1.2 \1326159933097.log
I am using disc one that came in the kop
Thanks,
JP
Unread 09-01-2012, 22:29
eulerddx4
Posts: n/a
Re: Can't Install Windriver
So, I put in disc two and that is working... It says install disc 1 first. Is it bad to install disc 2? I'm using windows 7
Unread 09-01-2012, 22:31
AKA: Brad
#0190 ( Gompei and the Herd)
I've been using Parallels, and I'm not sure if the difference is the issue. That message is a new one on me.
Is that an out of the box Windows 7 installation? Have you successfully installed other stuff on it?
Brad
Brad Miller
Robotics Resource Center
Unread 09-01-2012, 23:17
eulerddx4
Posts: n/a
Hello, Thanks for the reply! I actually just purchased this copy of windows and have installed solidworks.
Unread 09-01-2012, 23:19
eulerddx4
Posts: n/a
Using disk two only made me think it was working! It got to 47 % and gave me a similar error message...
Unread 10-01-2012, 00:58
eulerddx4
Posts: n/a
Case Solved! As Professor Miller hinted, there is some problem with VMware fusion. If you are on a mac and trying to use windows for coding in wind river either use boot camp or parallels. I am using parallels and it works perfect.
Thanks,
JP
