Go to Post The minibot horse is dead. Stop trying to beat it. Glue is too cheap. - Taylor [more]
  #31   Spotlight this post!
Unread 09-01-2012, 19:52
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Shooting from opposite side of the field
Originally Posted by davidthefat View Post
.... What motors are a good alternate for the shooter? Fisher Price ones?
Here are some comparisons of torque and rpm at maximum power.
CIMs: 45.00 oz-in; 4614 rpm.
BaneBots: 11.69 oz-in, 7300 rpm.
Fisher Price: 35.7 oz-in; 10500 rpm. (Model 0080-0673)
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #32   Spotlight this post!
Unread 09-01-2012, 19:54
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Originally Posted by Djur View Post
Here are some comparisons of torque and speed/volt.
CIMs: 343.27 oz-in stall torque; 443 rpm/volt.
BaneBots: 61.1 oz-in stall torque, 608 rpm/volt.
Fisher Price: 75.4 oz-in stall torque; unknown rpm/volt. (Model 0080-0673)
Darn you GDC for limiting the usage to only 4 CIMs... But the FP is the next best thing.
  #33   Spotlight this post!
Unread 09-01-2012, 20:14
Djur's Avatar
WPILib
AKA: Sam Carlberg
Maximum 2 FP, 4 BB. If you compare 2 BB to 1 FP per pitching wheel, this is what you get.
(Models used: BaneBot M7-RS775-12, Fisher Price 00801-0673)
BB: 2 * 11.69 oz-in = 23.38 oz-in @ 7300 rpm (Max power)
FP: 1 * 35.7 oz-in = 35.7 oz-in @ 10500 rpm (Estimated max power)
Fisher Price > BaneBot
Also, I should have put the values in that list at max efficiency. Fixing....
  #34   Spotlight this post!
Unread 09-01-2012, 20:46
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Just a reminder that some people don't always let the mere quantity of motors control the number of devices for which to use them.
(Of course, if you're planning on shooting while driving, this could be more complicated.)
  #35   Spotlight this post!
Unread 09-01-2012, 20:54
Djur's Avatar
WPILib
AKA: Sam Carlberg
There is a maximum of 22 motors... 4 CIMs for drive, 2 FPs for shooting, and 2 BaneBots or something for aiming a turret is only 8 motors.
  #36   Spotlight this post!
Unread 09-01-2012, 21:30
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
How practical does this look, what do you think of it?
For the most part the ball enter the back of the robot is picked up by a belt which uses force against plastic/rollers to move it upward and to the launcher. it gets to the launching part (motor sets B & C). Then Set B gets it moving to a good speed so that when it hits Set C, it is propelled even faster.
I tried to mark the ball path with a consistant line and marking it with arrows to get an idea of speed.
What you think? (sorry for the crude drawing, and not being to scale...)
Davis
  #37   Spotlight this post!
Unread 09-01-2012, 22:42
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by Ryan_Davis View Post
That's frightening.
Do the math on a feeder bot actually being a shooter bot that coincidentally only feeds even most of the balls shot.
Assuming half of the missed shots from beyond the barrier are picked up by your alliance and the other half are picked up by the opposing alliance, what do you get?
25% shot accuracy yields a 1.5-1 advantage over your opponents.
33% shot accuracy yields a 2-1 advantage over your opponents.
50% shot accuracy yields a 3-1 advantage over your opponents...
And that doesn't take into account that every ball you score as feeder is a ball your alliance partners don't have to go get and score, which gives them time to do other things (like either play defense or go scoop up balls to make that ratio better than 50-50.)
Now mind you, the distance error in a shot is approximately x*tan(theta), where x is the distance from the hoop and theta is the number of degrees between the perfect shot and where you actually shot. This translates into a maximum tolerance of about one degree at half court (ignoring distance discrepancies). Crazy, unlikely, almost unbelievable -- but we're going for it. At the very least, it should improve our shooting from the key!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #38   Spotlight this post!
Unread 09-01-2012, 22:56
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Who thinks that is it possible for a human player to make the shot from the corner? (doesn't matter which basket)
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
  #39   Spotlight this post!
Unread 09-01-2012, 23:20
pfreivald's Avatar
Possible, but not likely enough to make it much of a consideration in the game, methinks.
Team 1551
I write books, too!
  #40   Spotlight this post!
Unread 09-01-2012, 23:29
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I know it's possible. Our best shooter made it from half court on our basketball court twice without much practice and that was in a hoop at regulation height.
I think you are going to see this a lot more than you think.
  #41   Spotlight this post!
Unread 09-01-2012, 23:36
dtengineering's Avatar
AKA: Jason Brett
In '06 we could score from half court. In fact our autonomous mode was simply to have the driver line up the turret when they placed the robot, then spool up the motor (an FP, direct drive to a 6" wheel if I recall) and fire away.
We could have hit from further out, but the game had a built in speed-limit for the balls, so we were pretty much at maximum range.
Frequently, however, the balls would go in, but the massive backspin would actually toss them out of the aim high goal.
Backspin will be useful for stabilizing the flight of of the balls, but will also create lift, altering their trajectory and... in this game, unlike Aim High, will likely aid in scoring if you use it to bounce shots off the backboard.
My experience, however, after spending six weeks building a pan-tilt shooter that could (once you lined it up right) hit from anywhere was that in the time it took us to get our aim right, teams with far simpler shooters would drive in and hit ten shots from close range.
This year's target is smaller... there is nothing wrong with going for the slam dunk or lay-up approach... particularly if you have a hopper on the back of your robot that allows your "shoot from the other end of the court" colleagues to fire balls into your hopper (much larger than a goal) so you can finish the play.
Jason
  #42   Spotlight this post!
Unread 09-01-2012, 23:45
Andrew Lawrence
Posts: n/a
I think they should include in one of the updates that baskets made by the human player in the last 30 seconds of the match are worth more; maybe like the normal score +2, so as not to get ahead of autonomous, but to still allow teams to score while balancing on the bridge.
  #43   Spotlight this post!
Unread 09-01-2012, 23:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
They can't. This year the scoring is entirely automatic, hence the photogates at the baskets. There's no way to distinguish between a ball thrown by a human and a ball scored by a bot that will also allow for immediate scoring.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #44   Spotlight this post!
Unread 09-01-2012, 23:50
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
But did he have an 8' barrier in front of him?
  #45   Spotlight this post!
Unread 10-01-2012, 01:31
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Originally Posted by Brandon_L View Post
but we are limited to 4 CIMs this year, and about 99% of teams are going to use them for drive.
http://www.andymark.com/product-p/am-0932.htm
http://banebots.com/p/S24K-C1-7
So the question becomes, FP or banebots.
And also, if banebots, one gearbox or two hooked up to a single wheel shooter? (Limit 2 FP, 4 Banebots [R65], and correct me if I am wrong but each box takes two motors)
If you plan to camp in the corner and launch balls, you could probably get away with 2 CIMs in your drive. You're not going to speed past anybody, nor are you going to push them, but who cares when you're going to drive into the corner, wait until the end, and then drive up the ramp. If you do autonomous right, you'll never even touch an opponent.
