Go to Post I'll not deprive you of the practice in reading the manual; you'll need it if you want to be an effective part of an FRC team. - Alan Anderson [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 10-01-2012, 00:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Using an encoder with a two CIM gearbox
If I can remember, the encoder gets installed on the back side of the main shaft. So you would do it with any other way.
Unread 10-01-2012, 01:29
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The correct way to do this on board the Jaguar is to have the Jaguar firmware modified to include a "follow me" mode so you can implement a master and a slave Jaguar. Since that didn't happen for this year, the correct answer is to connect the encoder to the cRIO and to run the PID algorithm on the cRIO.
-Joe
Unread 10-01-2012, 09:22
Originally Posted by jhersh View Post
...the correct answer is to connect the encoder to the cRIO and to run the PID algorithm on the cRIO.
Consensus achieved.
Unread 12-01-2012, 11:02
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
is it posable to attatch one encoder to two Jags with diodes so it wont get feedback to the other one?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 24-01-2012, 12:37
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Doc543
If you use diodes the forward voltage drop will reduce the output voltage from the encoder (0.3VDC - 0.7VDC) and if you look at the encoder under that load you'll discover that might not be desirable.
More importantly you won't really get noise isolation from that.
Unread 25-01-2012, 01:46
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
-Joe
Just to share our experience from last year. We ran into the same encoder splitting issue on our lift and drive train... We were not successful in splitting one encoder to two Jags but were able to get something to work that's along the lines of what you're describing as a "follow me" mode.
We set one motor controller up in a speed control mode over CAN. We then queried that "Master" controller's output voltage. Then commanded the "Slave" motor controller (in VBus mode) to the Masters' voltage.
This obviously is not ideal as the slave controller will undoubtedly lag the master, however it worked in our testing. That said, we ended up not implementing closed loop control on the Jags for other reasons, and ended up not driving the motors in this configuration during the competition season.
If you are tempted to use this method of Master/Slave control, be conscious of the traffic generated on the CAN bus, especially if you're using the RS232 bridge
http://team2168.org
Unread 25-01-2012, 08:23
What were the other reasons?
Unread 26-01-2012, 10:33
Doc543's Avatar
AKA: Eric
what if you set one Jag to run the closed loop speed control and have the other Jag copy the output voltage of the first one?
Unread 26-01-2012, 11:18
http://www.chiefdelphi.com/forums/sh...0&postcount=28
Unread 26-01-2012, 13:48
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
We tried a number of different approaches, and like other teams we ended up running the PID loop on the cRIO. The best results we got was running a master/slave setup, but I didn't like it so we went back to just running the control loop on the cRIO.
You can successfully split the encoder, and we in fact ran them to both Jaguars and to the cRIO. But as I said, we ended up ignoring the inputs to the Jaguars.
Ideally, it would have been nice to have a firmware update that would have let us do this on the Jaguars, but no such luck. There was some talk that it might happen, and I was hopeful when there was a firmware update. Maybe next year.
Unread 26-01-2012, 19:37
Originally Posted by mjcoss View Post
The best results we got was running a master/slave setup, but I didn't like it...
Why didn't you like it?
Unread 26-01-2012, 22:51
otherguy's Avatar
sparkE
AKA: James
Time, and we had it working implemented on the cRIO...
http://team2168.org
