Go to Post i wish ours was done so i could get some sleep - keagara [more]
  #46   Spotlight this post!
Unread 10-01-2012, 00:18
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: The Barrier Thread
Originally Posted by ttldomination View Post
Who said that a WCD has to have 4" wheels?
- Sunny G.
This coming from an East Coaster, of course.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #47   Spotlight this post!
Unread 10-01-2012, 00:34
krazyman1013's Avatar
krazyman1013 krazyman1013 is offline
FRC #0701 (RoboVikes)
krazyman1013 is an unknown quantity at this point
Go on the bump at an angle with 6" wheels and you can clear the bump without damage.
  #48   Spotlight this post!
Unread 10-01-2012, 00:36
Ninja_Bait's Avatar
AKA: Jake Potter
Can you clarify and demonstrate that, please?
  #49   Spotlight this post!
Unread 10-01-2012, 01:13
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
I'm putting it out there and betting the majority of teams who weren't around for 2004 who try to climb over the barrier will end up like below.
You need to plan for worst case scenario, other robots contacting you and obstacles in your way as you try to traverse the barrier, if you choose to go that way. Trying to cross the barrier in your lab in a best case scenario would be as effective to your team as practicing your robot shooting at the hoops using a football.
Oh and for those of you who think you will not have damage to your robot if you just try to plow over the barrier at high speed, I suggest you do a real world simulation of this. Go find yourself some road hazard strips like this (or a simple curb) and feel the result of going over those even at 10 MPH. I think you will be surprised at the second thoughts you might have at just plowing into the barrier then.
-Michael Dessingue
  #50   Spotlight this post!
Unread 10-01-2012, 01:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Well, automobiles have a suspension typically, and honestly driving fast over most normal speed bumps works just fine. I'm not so sure I'd do it with a curb, at least not in my own car.
  #51   Spotlight this post!
Unread 10-01-2012, 06:55
pfreivald's Avatar
AKA: Patrick Freivald
I think he means to drive over them with an FRC robot(?).
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #52   Spotlight this post!
Unread 10-01-2012, 08:31
No I meant in a car, because a car is designed to absorb and disperse the shock of bumps and you will still feel it. Now imagine the shock with no suspension or dampening and having very little clearance.
[Yes i know there are many other differences to take into perspective also, like weight, but this is just to get brains thinking more toward reality.]
-Michael Dessingue
  #53   Spotlight this post!
Unread 10-01-2012, 09:18
pfreivald's Avatar
No I meant in a car
Very good, then... I liken to ramming the 4" barrier with a 6" wheel to ramming a 20" curb with your 30" car tire.
Team 1551
I write books, too!
  #54   Spotlight this post!
Unread 10-01-2012, 11:58
Back after 4 years off
FRC #5279
This is a terrible analogy, there is no connection between hitting a speed bump at 10 mph in a 4wd vehicle with suspension designed to drive on a mostly flat surface and hitting a 4 inch bar with a 120lbs robot that is being designed to do exactly that.
This just makes the analogy worse a standard car would clearly never climb a 20" barrier, that isnt what it is designed to do. A 6 or 8 wheel tank steer robot can easily climb over the 4" bar if the driver is smart about it and it the system is designed to do this. There will be a significant number of very good teams who stick with 6 or 8 wheel drive using 6 inch wheels. There will be less people tipping over due to going over the barrier than there were who tipped going up ramps in 2006 or 2010 or up the stairs in 2004. I would even guess that more robots will tip this season trying to go over the bridge than trying to climb the barrier.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
  #55   Spotlight this post!
Unread 10-01-2012, 23:33
pfreivald's Avatar
Sure, but I can see a relationship between speed and damage/wear here that's rather obvious if the system is not well designed.
Team 1551
I write books, too!
  #56   Spotlight this post!
Unread 12-01-2012, 20:24
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
HammadB will become famous soon enough
What are teams thinking to get over the bump, I am really confused as to how 6 inch wheels 8WD can do it w/out some sort of skid plate in the front to get off the ground, but then your climb becomes....ugly
  #57   Spotlight this post!
Unread 12-01-2012, 20:34
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
They are thinking about another way to get to the other side of the field whenever the bridge is being used or a robot died or something in that order. In my opinion it is a better choice to go over but every team has their own strength, weaknesses, and opinion for the features on the robot.
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
