Go to Post ...trapping Chuck Norris is worth infinity, Dave, Dean, and Woodie are 500 apiece, and trapping Andy Baker is worth double infinity - EricH [more]
Unread 10-01-2012, 04:01
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: How to construct a turret?
Disclaimer: I haven't looked at 1717 and 1323's turrets.
A motor and a belt going around what you plan to turn is enough to turn it.
You can math out how much it will turn in a certain period and then hard code any specific increment into the code, such that each button push moves it X degrees. It can also be done with shaft encoders and gyros, both which with some math can tell you the exact same thing, with some precision.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 10-01-2012, 08:52
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Here is a nice photo of FRC25 from 2006, it should give you some ideas.
-Michael Dessingue
Unread 10-01-2012, 09:53
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We had a turret for Lunacy - essentially, we took a lazy susan and riveted some belting around the outside. That belting went out to a small sprocket on a slow turning motor. Hook up an encoder to that motor, and you have some great control - due to the size difference (12" outer diameter for the lazy susan, 1 inch diameter for the motor sprocket), it took a ton of turns of the motor to get the turret through its entire arc, which allows you a lot of precision.
Unread 12-01-2012, 00:05
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
In 2009, 1726 made a turret out of a swamp cooler pulley. Here's the end result. We cut the spokes out of the middle and used the remaining bit of them to mount the turret, then attached bearings in strategic locations around the belt. There was slight wearing from the pulley-on-bearing action, but it was minimal.
