Go to Post You can expect to see the the same old same old again this weekend! Another set of fantastic experiences for thousands of kids across the country. And once again, Mission Accomplished. - Aidan F. Browne [more]
Unread 10-01-2012, 04:48
arshacker arshacker is offline
arshacker has a little shameless behaviour in the past
CLASSMATE USB KEY
THE KOP CHECKLIST REFERS TO 2 KEYS; E09 AND E11. MY TEAM GOT THE E11. WHAT IS EACH KEY FOR AND WHAT IS THE SEQUENCE OF INSTALL RELATIVE TO 2012 LABVIEW, UTILITIES AND DASHBOARD?
Unread 10-01-2012, 05:07
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: CLASSMATE USB KEY
First off, for sanity and courtesy, please don't use all caps in both the entirety of the post and the title of the thread.
As for your question, reimage with the usb key, validate Win7 (must have internet connection), click through the defender setup, Labview USB (Full, Tools or DS Installation, depending on which you want, refer to the instructions on the labview packet) then Java or WindRiver, if you use either. Then update the DS, and Utilities update.
All of this information is available in the Getting Started with the 2012 Control System PDF.
E09 i believe was given to rookie teams or teams who did not compete last year.
Please, don't just ask Chief Delphi because you have no idea. Try to find anything on the FIRST Site, and if you can't, see if there are any threads on the topic that you are confused about before you create a new thread.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 10-01-2012, 08:17
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
The 09 key is for 2009 and 2010 laptops,. The 11 is for 2011+ laptops.
This is generally true. If you purchased a spare at any time you need to flip the laptop over anx check the model number on the back.
My question is: if you have both types, how do you get the other thumb drive? Is there a download site?
Phil Malone
http://www.GEARSinc.org
Unread 10-01-2012, 08:34
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
In the past you could contact FIRST and you could get ahold of the USB drive for the one you didn't have.
Unread 10-01-2012, 11:09
musicman musicman is offline
FRC #2531
musicman is on a distinguished road
So if my team 2531 has a E10 netbook we should call and get the E09 flash drive?
Unread 10-01-2012, 13:56
The simplest answer is to find a local team that has what you need, and ask to borrow it.
Unread 10-01-2012, 14:51
PhilBot's Avatar
AKA: Phil Malone
Yes, that's definately the simplest answer.
Too bad we're 50 miles from the closest team, and 100 miles to the next one.
Phil.
Phil Malone
