Go to Post FIRST Isn't just about the robots, it's about Gracious Professionalism, co-opetition, and outreach also. - Julia Magoolia [more]
Unread 10-01-2012, 04:56
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Suggestion for driver station computer
So, now that we've gotten through kickoff, let's bump the topic.
My team is also considering a new driver station, especially in light of the added load of the Kinect.
What are other teams using and having good luck with? What suggestions are out there?
Cheap, rugged, compact would be pluses...
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 10-01-2012, 08:10
If you intend to use the Kinect on it, be sure to consider the HW requirements from the Kinect read me file.
Hardware Requirements
32 bit (x86) or 64 bit (x64) processor
Dual-core 2.66-GHz or faster processor
Dedicated USB 2.0 bus
2 GB RAM
Windows 7-compatible graphics card that supports DirectX 9.0c
A retail Kinect for Xbox 360® sensor, which includes special USB/power cabling
I've seen it run OK on that class of computer, but the i3, i5, and i7 computers had far more CPU left over.
Greg McKaskle
Unread 10-01-2012, 08:18
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
What version of Windows 7 is necessary?
Unread 15-01-2012, 09:15
Brian Holford Brian Holford is offline
GrimsleyEE
FRC #3215 (Prion)
Brian Holford is an unknown quantity at this point
Is there a Field Control System Setting Checklist for the driver station?
The getting started guide only has instructions for running the setup.exe file on the classmates, not configuring a user ID for a new computer.
Last year our team attempted to use Lenova Laptops instead of the classmate.
The first obvious error that we had was not formatting the "driver" user account name properly (case sensitive).
Then we had several problems with the internet connectivity not being recognized by the field. I'm pretty sure this was from not disabling the wireless adapter but the computer was not recognizing the wired network properly and our team unfortunately delayed a few matches while we were trying to resolve this.
In the heat of competition we opted to go back to using the classmate, but we certainly would like the option of more computing power on the field.
Last edited by Brian Holford : 15-01-2012 at 09:17. Reason: IIRC Development Season is done Wireless, FCS used Wired Network
Unread 15-01-2012, 10:43
The field no longer pays attention to the login name. Driver, driver, or chauffeur, it doesn't matter. I also have not seen issues with the wifi being left on, but that may depend on its IP address.
As to the original question, I can't say that I know of a checklist.
Greg McKaskle
