Go to Post Differentiating based on any superficial criteria (gender, race, or other demographic) only serves to reinforce the false idea that they matter. - JamesCH95 [more]
Unread 10-01-2012, 08:22
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
PhotoEye sensor, allowed?
Photoeye sensor referring to the sensor which most vending machines use to see if the item has dropped. We are looking at using 3 of these to determine if we have balls in our storing area or not. Instead of normal kill switches.
I'm assuming that it would be allowed as it is only a Digital signal but before we use any I'd like to make sure. I can't seem to find anything in the manual prohibiting them.
Unread 10-01-2012, 08:25
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: PhotoEye sensor, allowed?
So long as they do not violate any of the electrical rules, they are legal. Our team will be using them.
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
DjMaddius's Avatar
AKA: Matt Smith
Alright, sounds good. Thanks!
Unread 10-01-2012, 13:42
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Where do you find these Photoeye sensors?
thanks
Unread 10-01-2012, 13:55
Back after 4 years off
FRC #5279
As long as you use IR you should be fine, there are laser beam break sensors that serve the same purpose, these would have been illegal in previous years based on the ban on lasers. I am not on a team this year and have not verified this rule still exists.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-01-2012, 18:38
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
If it's a Class I laser, it has an exception from R08-D
[R08]
Robot parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other Robots.
Examples of items that will violate this rule include (but are not limited to):
Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any drivers and/or coaches and/or interfere with their ability to safely control their Robot
Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction
Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities of another Robot, including vision systems, acoustic range finders, sonars, infra-red proximity detectors, etc.(e.g. including imagery on your Robot that, to a reasonably astute observer, mimics the Vision Target)
Exposed lasers other than Class I.
COTS devices with completely enclosed integral lasers, such as a laser ring gryo, are permitted.
Flammable gasses
Any devices intended to produce flames or pyrotechnicsHydraulic fluids or hydraulic components
Teams should provide MSD Sheets for any materials they use that might be considered questionable during Robot Inspecttion.
Other electrical rules would still apply, though.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
