Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 10-01-2012, 02:42
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
How to construct a turret?
Hello Forum!
I have been scouring ChiefDelphi and other various resources, and I have seen much talk about using turrets as a method of aligning the shooting mechanism. However, I have not been able to figure out how one would power the turret to turn (and at such precise increments).
I've been specifically looking at team 1717's and team 1323's design. Can somebody delineate the confusion of the turret?
I'm assuming they both utilize a lazy susan of some sort.
Unread 10-01-2012, 04:01
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: How to construct a turret?
Disclaimer: I haven't looked at 1717 and 1323's turrets.
A motor and a belt going around what you plan to turn is enough to turn it.
You can math out how much it will turn in a certain period and then hard code any specific increment into the code, such that each button push moves it X degrees. It can also be done with shaft encoders and gyros, both which with some math can tell you the exact same thing, with some precision.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 10-01-2012, 08:52
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Here is a nice photo of FRC25 from 2006, it should give you some ideas.
-Michael Dessingue
Unread 10-01-2012, 09:53
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We had a turret for Lunacy - essentially, we took a lazy susan and riveted some belting around the outside. That belting went out to a small sprocket on a slow turning motor. Hook up an encoder to that motor, and you have some great control - due to the size difference (12" outer diameter for the lazy susan, 1 inch diameter for the motor sprocket), it took a ton of turns of the motor to get the turret through its entire arc, which allows you a lot of precision.
Unread 12-01-2012, 00:05
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
In 2009, 1726 made a turret out of a swamp cooler pulley. Here's the end result. We cut the spokes out of the middle and used the remaining bit of them to mount the turret, then attached bearings in strategic locations around the belt. There was slight wearing from the pulley-on-bearing action, but it was minimal.
Unread 12-01-2012, 00:25
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Originally Posted by Adam.garcia View Post
Hello Forum!
Could you reference the designs you are talking about? (links I mean)
Unread 12-01-2012, 00:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
We built an award winning & published turret system in 2006.
http://www.chiefdelphi.com/media/photos/33185
http://www.chiefdelphi.com/media/photos/25671
It was a custom lazy susan application with two plates. One on top of the other & a LOT of small plastic ball bearings riding in a grooved track between the two.
A motor driven wheel (shown below the plate on the left of the image) drove the top wheel & allowed everything on top of that including the motor driven shooter wheel to turn with ~340 degrees of motion.
The only reason we couldn't turn a full 360 degrees or beyond is because we had cables running up to the shooter motor we couldn't safely route around the turret as it spun.
The ~340 degrees was plenty of a range of motion we desired though in this instance.
If you can get a copy of the FIRST Robots: Behind the Design book from 2006, it is featured in there with a more in depth explanation.
Unread 12-01-2012, 00:47
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Nice work!
