Go to Post The robots are the attracting force, the common interest that brings us all together - sanddrag [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 10-01-2012, 09:22
Re: Using an encoder with a two CIM gearbox
Originally Posted by jhersh View Post
...the correct answer is to connect the encoder to the cRIO and to run the PID algorithm on the cRIO.
Consensus achieved.
Unread 12-01-2012, 11:02
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
is it posable to attatch one encoder to two Jags with diodes so it wont get feedback to the other one?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 24-01-2012, 12:37
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Doc543
If you use diodes the forward voltage drop will reduce the output voltage from the encoder (0.3VDC - 0.7VDC) and if you look at the encoder under that load you'll discover that might not be desirable.
More importantly you won't really get noise isolation from that.
